Automatic transmission fluid in manulal tranny
  • shields
    • Sep 2004
    • 46
    Today I decided to replace the tranny fluid with new Castrol Synthetic Fluid. As I opened the drain plug, guess what?! Red Automatic Tranny fluid! I don't get it, is this okay or has my tranny already suffered horrible damage due to the different viscosity of the automatic tranny fluid?
    I don't know why the last owner did this, is this common practice? :shock:
  • James Crivellone
    Head Janitor
    • 6304
    Use Redline MTL, problem solved
    • e30evolution
      West Werks
      • 1888
      some GL's are different colors.... put new fluid in and drive it see how it goes....
      ATF is just lubricating hydrolic fluid... as long as there was enoguht in there it should be ok
      http://www.westwerksauto.com
      • mspiegle
        • 1026
        some asian-made manual transmissions use dexron/mercon fluids. doubt it will kill it
        Michael Spiegle
        '01 Ford Escape / Daily Driver
        '99 M3 / Track Car
        '87 325is bronzit / wtf car
        '06 Daytona Triumph 675 / Daily Rider
        • Spaz
          Crazy Canuck
          • 2276
          ding ding, tried and tested
          it fucking works thats all!
          Cam .W '91 325is
          Spaz's 1991 Alpine White???? S52 Build Thread...
          • AdamF 88iS
            • 2051
            It's supposed to have ATF. BMW has been using ATF in their manual trannys for a while now. Get Redline ATF.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • m42technic
              • 1056
              I was hoping someone would touch on this.. ;)
              If you read instructions on Redline MTL, they say to use Redline D4 ATF in transmissions that require ATF. I dunno, I'd just rather take their word for it.
              James Peacock
              WWFSMD?
              • hamann318is
                • 3382
                I was going to use MTF but ATF, now I'm just confused.
                The BMW 318 is back. With a vengeance.
                • shields
                  • Sep 2004
                  • 46
                  Okay, That same day I drained the automatic tranny fluid that was in there and replaced it with Castrol Full Synthetic Gear Fluid. I don't know if it's the placebo effect, but i swear, she runs smoother now and gears change more smoothly.
                  • demlotcrew
                    • May 2004
                    • 297
                    Well the only E30 thats meant to have ATF in the MANUAL box is the 318IS, the new E46 and E36 M3 cars use AFT in the box, its meant to be better and when the box is cold you can change gear with ease. I use ATF in my box and its great.
                    Andrew
                    Andrew AT E30zone.co.uk | H23-is | S14
                      • 34839
                      you can still run ATF in the older E30 transmissions, I've also seen many reccomendations for it.
                      • hamann318is
                        • 3382
                        Considering I have a 318is, I guess ATF it is.
                        • Rob
                          • 8166
                          andrew- either you're confused or you meant to say they use MTF in the e36 and e46
                          BEERTECH
                          • demlotcrew
                            • May 2004
                            • 297
                            No dude i meant to say ATF, some of the guys here in the uk told me that the S52 lumps use ATF. But then again the ETK has part numbers for ATF and MTF ??? how starange. Anyway the guys said the boxes had ATF in them.
                            Andrew
                            • Rob
                              • 8166
                              fuck, i'm confused.
                              BEERTECH
