What makes e30 speedometers fail?
  • E30 Greece
    • Dec 2017
    • 1
    #31
    Speedo problem....please help!!!
    Hello from Paros island Greece
    My E30 M40 M52b25 has speedo problemand with speedo of cource the economymeter and the distance meter since both get from speedo
    I doesnt work or show less than real
    BUT when i full the tank and for 10-20km it works fine and shows real speed...also ecometer and distance work fine after tank full....but after 10-20 dead again.
    Any help???
    • izard2000
      • Dec 2017
      • 7
      #32
      Replacing E30 Speedometer head
      Hello everyone, I am currently seeking to replace the speedometer head only from my 1985 325e. I have found one from a 1989 325i and I was wondering if it would still be compatible despite coming from a newer model E30? Does anyone know if using a newer model speedometer head on an older model works??
      • superj
        • Feb 2006
        • 397
        #33
        it won't fit yours. you have the older style board and the pins for the speedo are different
        • E30_Driver
          • Feb 2020
          • 13
          #34
          Hello everybody. I hope you are well in this complicated period.
          While restoring my 1983 e30 there is a problem that seems impossible to solve: the speedometer (and odo) does not work. I state that the rest of the cluster works perfectly (even the lights of the board), the tachometer etc.
          From home, I carried out a bench test. I manually wired the connectors of the C2 (white) to see if I could trigger the speedo. With a wave generator I sent the signal to the pin 12, I wired the pin 8 and everything else, following the BMW manual. Result: the tachometer works perfectly! I then disconnected all the cables except the + 12v on pin 13, the signal at the pin 12 and -5v on the pin 8. Even in this case the tachometer works perfectly.
          Now, the problem is that when i mount the cluster on the car, it still dosnt work. I checked the fuses, checked the voltages on all the pins and also the grounds and I also replaced the differential sensor and checked that the signal reaches the pins from the wires on the diff. Again no solution!! Dead!!
          I then took the pin 12 (where runs the signal) and the pin 8 (negative -5v) and I connected it from outside to the signal generator. Again, nothing. The only try I will do tomorrow is to try to connect from the external even the pin 13..... Anyway, are there ghosts on my car or did I miss some steps?
          Thank you so much to those who will answer
          • tomstin
            • Mar 2015
            • 568
            #35
            You may want to reach out to these folks. http://www.bavrest.com/index.html
            2004 525i Manual - 1985 325E Coupe Manual
            • jbontke
              • Mar 2019
              • 449
              #36
              For anyone interested, my 86 325e VDO tach was not responsive. I tested it in a motometer cluster that worked, so I knew the issue was related to the odometer. None of the solder joints looked cracked. I also noticed that the odometer board can wiggle slightly when removed. When the odometer is installed, it tightens down but I bet hard bumps may cause it to move, thus stressing the solder joints. I went over all the solder joints on the board and the odometer came back to life. Give it this a shot before you throw it out.
