convertible blower motor?
  • norcalE30
    • Dec 2008
    • 932
    so i ruined the rear defroster pulling of the completely bubbled purple 80's tint (dont ask, rrreeeaallllyy long story)
    i want to know if i can use the rear defroster blower from an ic on my rear window. i see theres two vents facing the window in my rear tray, is that what theyre for? i cant see out the back window in the morning....
    Originally posted by kronus
    pff, all of you are slow as hell anyway. Eta > all
    I'm not sure how much help just a blower would be. In most cases, you need heat to defrost.defog a window. I'd think the path of least resistance would be to get a good used window from a salvage yar.
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      I believe those 2 vents you speak of are nothing but holes to allow air to move more freely around the base of the window, they don't have any forced air traveling through them. I suppose you could try and rig up an iC blower underneath your parcel shelf, aim it correctly, wire it in to a 12V source and then to your defroster switch, but I think it would be easier to just get a new window. Or, try one of the various 'rear defroster repair kits' available in the interwebs or your local auto parts store.
      • norcalE30
        • Dec 2008
        • 932
        yeah ive seen those kits, idk if theyll work tho cause i pretty much pulled the strips completely off... id rather not get a new rear window if i can avoid it
        • DaveSmed
          • Apr 2007
          • 1407
          You could defog the window faster by farting at it instead of using the iC blower.
          Why are you trying to avoid changing the back window? Very easy on E30s since they are not glued in like most cars.
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • AndrewBird
            The Mad Scientist
            • 11898
            I believe those vents on the rear shelf are vents for the trunk. When you close the trunk, air can escape through there so the lid will close easier.
            • norcalE30
              • Dec 2008
              • 932
              oh okay, nvm then, im just cheap and dont wanna buy a window lol
