Well, i've been trying to diagnose the problem my '91 318is has for about... 3 or 4 months now. No luck...
Car hasn't started in months now...
Here's what i've tried:
check fuel pressure: 55psi
check compression: good
replace afm: (wasn't getting signal... am now)
check crank and cam sensors... seem good.
Put noid lights on injectors: Iratic firing, but signal none the less.
Check spark: good
There doesn't seem to be any fuel exiting the injectors... so obvoiusly no starting
There is a black box under the intake manifold that both the cam and crank sensors are plugged into... but i can't find any explanation on the box. I suppose it could be a simple junction box, but i can't find any mention of it in the bently, or the snapon wiring diagram.
Anyone got any info on the mystery box? Any ideas AT ALL??? If you've got an idea, you're way ahead of me... i'm lost and i need a car :(
Check spark: good
