anybody seen this water leak before (trunk)
  • robspeed325i
    • 403
  • ethree
    • Aug 2007
    • 1216
    It's the trunk gasket no? The water just trickles down there from wherever the leak is.
    1: Sunroof drains
    2: Taillight gaskets
    3: Trunk gasket
    • robspeed325i
      • 403
      it is obviously not 1, or 2. must be 3, as there *is* a chunk missing from the middle of the gasket, just above/near the latch. how can water crawl up under there tho?? strange...
      • AlpineIS
        • 161
        Most likely it is the gasket. If I were you I would pull it and inspect it further because if you've got water collecting underneath the gasket the thin metal lip (which the gasket grabs onto) will rust. Ask me how I know... :???:
        • a3ternus
          • 643
          Happens to my car,too! :(
          I just finished using silicone around the suspect rear light,
          but still I get humidity in there.So,how do I fix this?
          N.
          Originally Posted by aaron_silva
          It is always frustrating having a harsh ride when
          you arent in the right mind set.
          • twright
            • 707
            The easiest way to find a leak (after it warms up) is to get in the trunk with a flashlight .
            Then, have someone you trust (so he'll let you out when you're done) turn a hose on the trunk. The source of the water leak will be instantly obvious.
