about transmission swap
  • davide30
    • Sep 2004
    • 7
    me i have also 325i 1990 automatics 4 gear and i have getrag 5 speed manual, people know about tis swap please let me know ???
    David
  • Rob
    • 8166
    read that for starters
    BEERTECH
    • davide30
      • Sep 2004
      • 7
      thank you , but he dont talk about the pedals, and detail like that ???
      • Rob
        • 8166
        no way you read that entire thread in 3 minutes.
        BEERTECH
        • Jordan
          • 12913
          Maybe in 33 minutes though rob. How be that there numbers learnin coming.
          https://mtechniqueabs.com/
          • Rob
            • 8166
            derf
            BEERTECH
            • Bill 84 318i
              • 1600
              Assuming you know the basics about transmissions and how they work...
              There is pretty much no custom work involved. Here's a parts list:
              5 spd transmission and driveshaft
              Flex disc and center support bearing (new isn't a bad idea)
              Flywheel (resurfaced)
              Pilot bearing (new)
              Clutch assembly (new disc, pressure plate, throwout bearing, pivot pin)
              Master and slave cylinders (not expensive new)
              Clutch hydraulics (one solid line, one rubber line, one cloth kind of line)
              Shifter assembly (good time to put in a short shift lever) with new bushings
              Pedal box
              Any seals you want to replace
              Misc. hardware: new flywheel bolts, pressure plate bolts
              That's about it, off the top of my head.
              Any specific questions?
              • James Crivellone
                Head Janitor
                • 6304
                Me and TJ just did the swap, its not really that difficult.
                bill just summed up most of the details, anything in paticular you want to know?
                • Digitalwave
                  is a poseur
                  • 6293
                  The only custom work I had to do was making a hybrid pedal box. The manual pedals I got were from a non airbag car, and my car had an airbag. The airbag pedals support the back of the steering column. When I installed the non airbag pedals in my car, I could move my steering wheel up-down about 12". I had to cut up the old pedal box and fabricate a bracket to go in place of where the new pedals SHOULD have supported the back of the steering column. Pretty easy fix nonetheless.
                  RISING EDGE
                  • T.Dot E30
                    • Mar 2004
                    • 536
                    Quick Question
                    Is the flywheel the same? you didn't mention if it was
                    • Digitalwave
                      is a poseur
                      • 6293
                      Originally posted by T.Dot E30
                      Quick Question
                      Which flywheels?
                      RISING EDGE
                      • James Crivellone
                        Head Janitor
                        • 6304
                        Quick Question
                        you need to replace the flywheel obviously, the automatic flywheel is not built for a clutch at all
