On the road help!
  • Elan+2
    • Jan 2009
    • 6
    On the road help!
    I am traveling out of state to visit family. Alternator belt broke at the house, I have only a few tools. What would be the best way to replace with limited tools? What would be the easiest steps to remove only nessisary parts?
    Thanks
  • E30SPDFRK
    • 5707
    Does the alternator still spin freely? If yes, just loosen the tensioner on the alternator, put the new belt on and tighten it all up again.
    Where are you broken down? I'll bet there is someone on here that is near you.
    Byron
    Leichtbau
    • Elan+2
      • Jan 2009
      • 6
      Do you not need to take the other front belt off? Also the crossover water pipe does it need to come off to be able to get the belt on the fan pulley?
      • deutschman
        • May 2008
        • 5958
        are you a bmw cca member? if so you should see if there are any cca members around that can help you out.
        • Elan+2
          • Jan 2009
          • 6
          No I am not. I am visiting in a very rual area of north Ga. and would like to fix tonight.
          • Mitchel
            • Jan 2009
            • 35
            You should be able to loosen the tensioner easily and replace the belt. There should be a diagram of the belt placement in your engine bay.
            1998 Hellrot M3, perpetually on jackstands
            1985 325e
