complete "e" to "i" swap- parts list, in
  • Rigmaster
    • 3464
    Guys,
    I'm getting ready to help a friend convert his '84 325e to an "i" drivetrain. His car is a 5 speed car, so we are planning to use his tranny, but we're trying to come up with a comprehensive list of the parts needed to complete the conversion. (I already have most- if not all- of the "i" parts we are going to need- we just want to make sure)
    Here's a list of the main things I could come up with in the last few minutes:
    - Complete "i" motor with engine wiring harness + ECU (aren't the early/late harness connectors different??)
    - "i" AFM, intake boot, ICV, etc
    - "i" instrument cluster (or at least the tach)
    - "i" flywheel (unless his car has the non-dual mass flywheel) with "i" clutch (he has an almost new "e" clutch in there- so we will use it if we can)
    - "i" exhaust manifolds + exhaust system (dual pipes)
    Anything else (small or large) that we have not thought of????
    Thanks!!
    Bret.
  • Fred
    • 659
    You forgot about the C101 (engine harness to fusebox) connector. The harness plug is round, the fusebox connector is rectangular.
    '86 325 2.8i stroker - Arctic Blue
    '11 328i Sports Wagon - LeMans Blue
    Strictly Eta
    • James Crivellone
      Head Janitor
      • 6305
      rear differential of 3.73 LSD
      1st gear will be pretty damn long with teh stock 2.79:1 diff
      • Rigmaster
        • 3464
        Thanks- we've got the diff situation covered (it's getting a 373LSD). I was mainly looking for engine-related things.
        Bret.
        • surebimmer
          • Jan 2004
          • 978
          Are you going to swap a "i" motor into the "e" or build a 2.7L?
          • Mitch M
            • 881
            Re:
            Couple things I discovered on my e to i swap.
            9/85 w/ proper round C101 connector
            Hole through the firewall needs to be enlarged.
            i computer uses a different mounting bracket
            ETA starter uses round stud plug....i uses female spade
            Alt no issues...use urethane bushing if ETA. i is all metal and 10 more
            amps
            Oil level sensor plug is different on late "i"s...just need the proper level
            sender.
            Late "i" engine harness uses different style c104 plug. Same # of wires.
            I had no tach signal issues w/ the 87 i harness.
            323 / 318 tach in ETA cluster or entire 323 cluster hit limiter @ 5900
            indicated. Switched to the newer codic lower right style cluster and had the
            proper 6400 tach
