hit rev limiter going downhill
  • Nic01101011
    • Jan 2008
    • 1549
    right after I did, and shifted into the next hear, the car didn't have any power. it sort of just hung there at the same RPM. a bit of shifting back and forth, and the car was back to normal.
    car sat for a few days then drove home fine. but when I later went to drive it it would buck under acceleration and have little power. anyone know what might be wrong?
  • SamE30e
    • Sep 2007
    • 4319
    Popped something possibly. Did you do a compression test?
    1985 325e 2.8 Turbo VEMS
    • rThor432
      • Feb 2007
      • 3907
      That's how I blew up my ignition rotor. But then the car didnt go any more.
      • Nic01101011
        • Jan 2008
        • 1549
        i havent done anything yet, its been raining and I don't have a garage
        the odd thing is that it drove alright for a while then only later started acting up. ill try driving it tommorow to see what happens
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          Broken rocker.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • Nic01101011
            • Jan 2008
            • 1549
            update on symptoms
            the car drives smoothly, but is down on power. it sounds fine, i really don't think anything mechanical broke.
            • dude8383
              • Jan 2005
              • 10387
              don't know till you pop of that valve cover and have a looksy!
              • Nic01101011
                • Jan 2008
                • 1549
                wouldnt a broken rocker arm make a lot of noise and run really roughly?
                • acefreely02
                  • 19
                  its a broken rocker arm, ive done 3 already, first was was kinda a little ruff soun ding the other 2 didnt sound bad just down on power, they broke but letf enough to open the valve a small amount.. i can almost guarrenty its a broken rocker arm, most likely and intake one
                  • Nic01101011
                    • Jan 2008
                    • 1549
                    assuming it is a rocker arm..
                    is that an easy fix, do i have to pull the head?
                    also, is it a bad idea to be driving around?
                    • scabzzzz
                      Estado de mierda de encargo
                      • 6870
                      What, you dont have spare rocker arms lying around?
                      I thought that was a necessity of owning an E30?
                        • 34839
                        if it's an intake rocker, you can still drive it (assuming you've removed all the broken peices), but not if it's an exhaust rocker. you can unplug the injector going to that cylinder so it's not wasting fuel until you have a chance to change the rocker. you can also replace it without removing the head, it's tricky but not impossible.
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          If your motor is old enough to break a rocker you really should pull the head and redo it with new stuff all around. We just had a customer with a broken rocker and when we pulled the head we found the cam was completely worn out. This motor had supposedly been rebuilt 60k miles ago, but probably with the old parts. Suck it up and do the work properly, even though it will be expensive. At least you'll have a fresh head and it's a good opportunity to upgrade while you're in there.
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            Haha, I know I have like 20 of them, pfft hint hint
                            -Andy
                            • Spinning Tires
                              • Feb 2007
                              • 283
                              My M20's lived on the rev limiter and i never broke a rocker. Just lucky it seems
                              First: 1984 318i
                              Second: 1987 325
                              Third: 1987 325is
                              Current: 1990 325i (Soon To Be 335i)
