But the bubbles eliminate turbo lag, didn't you know that!
Why not sttrap Dry Ice blocks to my engine?
By breaking the blocks into smaller pieces you can change the curve of the torque and where it crosses. The formula is simple it's
BxR/2 = X
B being the size of the ice, cubed
R being the idle RPM
and X being the RPM where the torque crosses the HP line.
Hope this helped with your awesome idea!1985 325e 2.8 Turbo VEMSComment
Since your car is a V6 it should work fine, but BMW pushrods are weak and you might blow the welds on your intake.'74 2002 - Build blog at
nomads2002.blogspot.comComment
I use a nitrous kit but with a CO2 fire extinguisher instead of a nitrous bottle. Its cheap and there was so much power my engine got confused and shut offFirst: 1984 318i
Second: 1987 325
Third: 1987 325is
Current: 1990 325i (Soon To Be 335i)Comment
I bet this will also work well on automatic transmissions.. With all that power going through, it would help immensely to cool it down and reduce swelling and excessive "sweating". No more oil stains from your leaky transmission!
I'd be worried about redbull tho.. too much sugar and caffeine. unless they have organic decaf redbull; i'm down for that. it's probably cheaper than a can of seafoam.
it works with auto guise, j make shure you dubble clutch like you should!Comment
