Coolant boiling over, questions...
  • eric1855
    • Sep 2004
    • 69
    I was AutoXing my new 325is yesterday and it was a fairly warm day about 85 or so.
    The car, after i would let it cool and shut it off, in the grid, it would start puking coolant. On the tank in the engine bay, with the filler cap, there is a hose on the passenger side of it that comes off, and on my car, it goes to nothing. the coolant was coming out of this hose. Is this hose supposed to go somewhere? It hasnt done this before.
    Is it a closed system? Or perhaps is my pressure cap going bad?
    Anyhelp would be great apprecaited. Thanks
    Eric
  • reelizmpro
    • 9543
    Sounds like it's not holding pressure, check for cracks and try another cap.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • BahnE30
      • 1050
      my car did this once. i snapped the alternator belt which also runs the waterpump and fan so it got up to about 3/4 temp before i noticed it pulled over and there was a trail of coolant behind the car
      it's just an overflow tube for the expansion tank. it should only do this when the car runs hot. i wouldn't be really worried about it if it did it during an autocross when your driving hard i'd keep and eye on things thou for sure
      • demlotcrew
        • May 2004
        • 297
        Do you have anti freeze in the water mix?
        Andrew AT E30zone.co.uk | H23-is | S14
        • Spencer
          • 767
          On my eta I had an overflow hose coming out of the coolant reservoir.
          -Spencer
          • Jand3rson
            • 37587
            -Spencer
            They all do...
