Rough idle...warning lights on verrrry dim
  • KillerCalypso
    • Jan 2004
    • 459
    Im up at school in NH now and my car is in CT but i was thinking about going to get it this weekend for show n' shine at bav auto. The thing is before i take it on the trip there were a few things that concerned me when i left it. The last day or so when i was driving it it had a rough idle and at night i noticed that all of the dash warning lights were on but very dimly lit, also i think i heard a slight whine that carried through the rev's (maybe till about 3500rpm) but i cant be to sure because the tri flo is just a little to loud Everything else seems fine, engine pulls strong and starts with no problem.
    Any thoughts? Or anyone else going to show and shine this Sun?
    Thank you guys
    Andy
  • Charlie
    kid tested, administrator approved
    • 6686
    Alternator's DOA.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • shields
      • Sep 2004
      • 46
      Originally posted by Charlie
      Alternator's DOA.
      -Charlie
      :idea:
      Tru dat!
      Your Alternator (generator) is shot bro...
      • KillerCalypso
        • Jan 2004
        • 459
        Are all of these symptoms that i have listed true of needing a new alternator?
        • Jordan
          • 12913
          Its time for a new alternator for sure.
          https://mtechniqueabs.com/
          • KillerCalypso
            • Jan 2004
            • 459
            How long can i limp on a dying alternator?
            Thanks for the fast reply
            Andy
            • UNHCLL
              • 8790
              not long enough to safely get you from CT to NH :(
              Below the radar...
              • Jordan
                • 12913
                I wouldnt leave the neighboorhood. No joke.
                Right now your alternator is most likely producing 10-11 volts maximum, and low amperage as well. Sooner or later your engine will start to misfire as your battery slowly drains out.
                Seriously. I wouldn't take it any further away from home then you want to push it.
                • BMW BMXER
                  • 2325
                  Ya you can not limp around no alternator. Mine died and I was fucked literally, could not do shit.
                  Sold it.
                  • Axxe
                    • Aug 2004
                    • 3355
                    My belt snapped 80km away from home. I figured I could make it since it was charging well before, but I only managed 40km before my fuel pump ran out of power. Thank fully I limped into a Canadian Tire and bought a new belt and got a boost. It's scary shit man, the last 20km I had 0 lights inside, and the car was misfiring like shit. Don't take it out of the neighbourhood.
                    Keep it slideways!!
                    • 325beast
                      • May 2004
                      • 20
                      Try replacing the brush/diode assembly before you spring for a new alternator. I did that to fix an identical problem and 30,000 miles later and still running the original alternator. I did visually check that the brushes were too short and grooved.
