Fuel System Issues
  • Nygdup
    • Jul 2006
    • 418
    Fuel System Issues
    First off.. I tried searching for this, but it gave me 10+ pages to sort through.
    Bought an 89 vert this morning with fuel system issues. Fuel pump is not kicking on.
    Started the morning by replacing the pump and the relay with known good pieces. Still not kicking on. Any thoughts?
  • Rolla1990
    • 199
    Check the fuse? Can you jump power to that circuit at the fuse box and get it to turn on?
    Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
    • Nygdup
      • Jul 2006
      • 418
      All fuses are good. I tried jumping the fuse anyways.. no change.
        Are you checking the pump when cranking the engine? The DME won't run the fuel pump unless it is working and sees timing data from a rotating engine.
        • Nygdup
          • Jul 2006
          • 418
          I don't even have the fuel filter currently installed. If the fuel pump were running then I SHOULD have a puddle of gas under the car.
          • Todd Black 88
            • Oct 2007
            • 3449
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • Nygdup
              • Jul 2006
              • 418
              Oh, I read the emphasis of his question wrong.
              Yes, I am cranking the engine. No fuel delivery.
                Okay, is there spark when cranking the engine? No spark and no fuel pump operation would be:
                1) No power to the DME
                2) No Start signal to the DME
                3) No timing reference data to the DME
                4) Bad DME
                • Nygdup
                  • Jul 2006
                  • 418
                  Cool.. now at least I have a checklist for tomorrow.
                  Check for spark.
                  If no spark, swap DME and crank position sensor.
                  • Spinning Tires
                    • Feb 2007
                    • 283
                    i had a problem just like that but it was intermitten. as long as it has no spark that turned out it was a faulty power wire to the computer. check for power going to the fuel pump relay
                    First: 1984 318i
                    Second: 1987 325
                    Third: 1987 325is
                    Current: 1990 325i (Soon To Be 335i)
