I was wiring up the relays as stated in the DIY threads, reconnected the battery and tested it out and popped fuse #28 and smelt a bit of smoke.
When the key is on position #1 and I flick the high beam switch I hear the K3 relay click so it is working but get no high beams.
When I pull out the headlight switch I get no lowbeams but my citylights are on.
When I push the fog switch I get no fogs.
The windows do not work and I checked fuse #17 and it is fine.
So any idea of what I f*cked up?
