Weight in trunk..
    Weight in trunk..
    Probably a stupid question, but as i was cleaning the trunk of my cabrio today, i noticed, where the battery is, there was a large box looking thing. Upon removal, its a heavy ass weight. I'm assuming this is to simulate the weight of the battery, since it's in the engine bay.
    Yeah, mr. silva discovered this too. Take it out and move your battery to the trunk. :P
      also peel up the 3/4" thick slab of crap lining the bottom of the trunk if you have it.
      Im now E30less.
        Who doesn't love a little BBQ?
        Griot's Garage at a Deep Discount
          under the carpet. its usually painted to match and its a heavy tar slab that weights ~40lbs
          Im now E30less.
            Dont have it, guess BMW decided the gigantic weight and the convertible top was enough weight in the back of the car :P
            ///M powered, i dont have the neccesary parts.
              what good does it do?
                I think it's just extra weight over the rear wheels to help traction...but it really only helps in the winter.
                  Weight balance, more than anything.
                    Help any if I remove it?
                    Or should I leave it be?
                        i'm leaving the "ballast" in the trunk, unless i remove serious weight from the front of the car, too. i've heard it was for weight distribution (handling). i figure the bmw engineers knew what they were doing.
                          :up:
                            Never seen this in a UK E30. I dont think this would make that much of a difference on the handling.
                            Andrew AT E30zone.co.uk | H23-is | S14
                              I removed mine since I have a large sub box that sits right over the rear end. I figure without the 50lb lead weight and the heavy spare tire my stereo system off sets the difference and balances it out... I haven't put the car on a 4 wheel scale but I'm think I'm close. The handling feels the same with or without it.
                              M
                              I could also be there to help with traction but since I now have a lsd I don't have traction issues any more
