What's your car weigh?
  • immajackuup
    • Dec 2010
    • 1132
    #61
    wow,I thought e30 weight much as a civic.
    • Jean
      • 18228
      #62
      84 318i full interior but with no a/c compressor, no spare tire and no jack.
      euro bumpers/mtech valances
      m30b35 swap
      half a tank of gas
      16 with 225/45 tires
      nothing removed or cut, there was no tar in the trunk or under the seat.
      2500lbs on the dot per race shop corner weight scales.
      • ForcedFirebird
        • Feb 2007
        • 8300
        #63
        Condor Speed Shop GRM car was just over 2100 with a full tank...
        john@m20guru.com
        Links:
        • a3ternus
          • 643
          #64
          WTF? E30 318i M10 with AC,full interior, half tank,spare wheel,15'' wheels and everything in place: no more than 1050kg (around 2300lbs)! The problem is I weigh 265lbs! :P
          N.
          Originally Posted by aaron_silva
          It is always frustrating having a harsh ride when
          you arent in the right mind set.
          • Jaxx_
            • Dec 2009
            • 1880
            #65
            N.
            are you saying it was 2300 with or without you in it?
            • e30trooper
              • 11576
              #66
              any light verts?
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                #67
                Originally posted by e30trooper
                any light verts?
                • a3ternus
                  • 643
                  #68
                  Thats the weight without me!
                  N.
                  • Pipes
                    • Aug 2012
                    • 485
                    #69
                    1991 318is w/S52 swap, no A/C. Full stock interior, basketweaves, spare and toolkit in the trunk, full tank of gas, no driver: 2660
                    Without gutting the interior, what is the best weight loss strategy? Does power steering weigh much? What about sunroof vs slicktop? Swap to crank windows?
                    1991 349is (wadded up)
                    1984 Rabbit 2.0L16v swap (wife's)
                    2003 LR Disco II (wife's)
                    1993 MB 400SEL (son 1's)
                    1980 MB 450SEL (son 2's)
                    2004 KTM 525 EXC-R SM Sold:(
                    • VinniE30
                      • 2113
                      #70
                      You'll loose the most with exhaust, but you probably already have a much lighter exhaust with a 24v swap.
                      There's no really big things where you loose over 50 lbs except exhaust and removing sound deadening. It's all little things here and there that add up.
                      With a lot of things you kill two birds with one stone like if your doing coilovers anyway you save a few pounds there, if you're upgrading brakes anyway most of the common caliper upgrades are lighter than stock.
                      You've probably already done most of the engine bay stuff since you did a 24v swap.
                      Unfortunately there aren't any good fitting carbon fiber hood options available anymore.
                      Zinno '89 <24v swap in progress>
                      • ak-
                        • 12422
                        #71
                        Taking out your sunroof is more of a "lower center of gravity" mod instead of weight savings. It's like 30lbs I think. Just like seats bolted to the floor.
                        1991 325iS turbo
                        • fronton
                          • Oct 2009
                          • 1262
                          #72
                          2,720 with a full stock interior and a s38
                          • Bearmw
                            • 1323
                            #73
                            I have not yet weighed my 89 vert but expect it will be fairly light even with the B35 swap because of: cfrp hood, D-force 15x7's, UUC BBK, no A/C, lighter exhaust, removed trunk tar, "modified" diving boards, no fogs, Recaro LS-B's, and some other small stuff. Some things have added weight such as Luke box, Raceskids cross brace, skid plate, IE strut bar...
                            I may do more for weight loss but am at the point of diminishing returns. I like power steering. I plan to get it accurately weighed at some point.
                            I would also like to see some lighter vert weights.
                            • Sagaris
                              • Sep 2009
                              • 2243
                              #74
                              1991 325i automatic 1/2 tank of fuel, A/C and trunk tar removed, no driver 2720 lbs
                              it is now manual swapped with more weight reduction and am hoping for closer to 2600 when I weigh it again.
                              • E30SPDFRK
                                • 5716
                                #75
                                Bump from a better time, wondering what’s the lightest someone has got their car to while keeping a full interior.
                                I weighed my car yesterday; 84 318i, no AC, no PS, lighter exhaust, 325i brakes and strut housings, medium case diff, nearly full tank, no driver. 2330 lbs. I’m gonna try to get it down to under 1000 kilos with the full interior still.
                                Does anyone have me beat?
                                Byron
                                Leichtbau
