Fuel Problem?
  • agile30
    • 832
    Fuel Problem?
    So for a few months now my car has had this issue that gets frustrating that I believe may be fuel related. Whenever I give it alot of gas it will start missing really bad. But when I slowly creep on the gas to wide open throttle it runs fine. The other night I popped open the hood and you could smell gas. It also seems like it is running rich....... Any advice on what it could be? The car is a stock 91 318is
    Originally posted by Good & Tight
    It takes real man to mount a big woman, all you haters are just scared boys.
  • Spinning Tires
    • Feb 2007
    • 283
    Fuel Pressure Regulator maybe. take off the vacuum line going to it. start the car. see if gas comes out
    First: 1984 318i
    Second: 1987 325
    Third: 1987 325is
    Current: 1990 325i (Soon To Be 335i)
    • Liam
      • 753
      Check your cap and rotor, spark plug cables and spark plugs (basically the secondary ignition system).
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
      • E30_fiend
        • Apr 2006
        • 7348
        three letters A F M.
        check it
        • Spinning Tires
          • Feb 2007
          • 283
          AFM and ignition do not make it smell like gas under the hood unless you have a gas leak too. If thats the case and your leaking gas and arcing a spark at the same time you better buy a fire extinguisher
          First: 1984 318i
          Second: 1987 325
          Third: 1987 325is
          • Liam
            • 753
            Air flow meter is possible but would not respond well to gradual acceleration either and yes raw fuel smell isn't a good thing.
            Yes a fuel pressure regulator could be suspect as well, test the pressure.
            • bimmerboy12
              • Jun 2004
              • 1057
              in addition to checking the fuel regulator, check all your fuel hose junctions, especially the cluster of 4 hoses that meet at the black plastic connector about a foot under the throttle body. This was leaking in mine to produce intermittent fuel smell. Check while running cause it evaporates quickly.
              1988 325iC Project - FINISHED!
              Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
