Need some help
  • brodee
    • Jan 2004
    • 2914
    Need some help
    I was just driving my '87 325e and all the instruments on the dash quit except the speedo. Also the blower motor for the AC quit at the same time.
    I noticed when I restart the car the tach and all gauges work for about 2-3 seconds and then 0 out again.
    Anyone have an idea on what I need to check?
    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
    1988 M3 - Track Rat
    1989 325iC M50 Vert
    1989 325i Coupe
    1991 318is
    1995 318ti Club Sport
    2006 330i e90
    2008 Tundra Crewmax
  • M-technik-3
    • 18946
    SI board batteries...... common happening as rechargeables don't last forever..
    • brodee
      • Jan 2004
      • 2914
      I didn't realize they had anything to do with the blower motor.
      1988 M3 - Track Rat
      1989 325iC M50 Vert
      1989 325i Coupe
      1991 318is
      2006 330i e90
      2008 Tundra Crewmax
      • dgspikes
        • Mar 2004
        • 179
        not to jack your thread, but my tach and the mpg thing went out yesterday, it kind of slowly went out, it was all screwed up for a min then now just dead. is there a fuse or something i gotta check
        • jblack
          • Aug 2004
          • 98
          2 things....DGSpikes, see the response by M-technik-3 above - probably not a fuse, it's probably the SI Batteries....
          and Brodee - you will get more focused and better responses if you are specific in the subject line - rather than using "Need some Help", try "Dash gages and AC quit" - I promise you will have better luck!
          • brodee
            • Jan 2004
            • 2914
            I appreciate the advice but my experience with this board has shown me that broader topics get read by more people. The small few on here that know the technical aspects will read the post eventually and someone will hopefully chime in and let me know an experience they have had similar.
            1988 M3 - Track Rat
            1989 325iC M50 Vert
            1989 325i Coupe
            1991 318is
            2006 330i e90
            2008 Tundra Crewmax
            • brodee
              • Jan 2004
              • 2914
              In case anyone searches and finds this later, it turned out to be fuse #10. I had checked all the fuses and none looked blown, even after taking this one out and looking at it closely it looked fine.
              Anyway, problem fixed as long as it doesn't blow again.
              1988 M3 - Track Rat
              1989 325iC M50 Vert
              1989 325i Coupe
              1991 318is
              2006 330i e90
              2008 Tundra Crewmax
                • 37829
                If the SI batteries are bad, it will. My friend played that game for a while, replaced #10 like 5-10 times a day, finally he fixed it, lol.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • brodee
                  • Jan 2004
                  • 2914
                  I replaced the SI batteries too since I had already taken the dash apart.
                  1988 M3 - Track Rat
                  1989 325iC M50 Vert
                  1989 325i Coupe
                  1991 318is
                  2006 330i e90
                  2008 Tundra Crewmax
                    • 37829
                    Cool Cool.
                    Grover Beach, CA
                    www.BimmerHeads.com
