Upgraded Clutch Master Cylinder available for E30? or is my clutch too heavy...
  • fastestbox
    • Jul 2018
    • 124
    Apologies if this is in the wrong section, I was conflicted between putting it in the Brakes or the Transmission section and then I realized it's technically not.
    I (mistakenly) purchased a ClutchMax chromoly flywheel with a stage 2 clutch and my clutch pedal is stupidly stiff. I'd like to say I've got a strong left leg and I've driven cars with upgraded clutches but this is honestly dangerous as far as me popping it out accidentally in stop and go. Obviously as it's an eBay setup there's not a whole lot of documentation on the setup and I really don't want to pull the transmission to replace it with an easier clutch and I may as well replace the clutch master.
    Does an upgraded/uprated clutch master for the e30 exist or am I barking up the wrong tree?
    My setup is a:
    ZF320
    Clutchmax chromoly LTW flywheel
    Clutchmax stage 2 sprung clutch
    Brass pivot pin
    E36 328/Z3 Slave
    Stock E30 Master
    Condor stainless clutch line
    What do R3v?
    91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
  • fastestbox
    • Jul 2018
    • 124
    Anyone? I really hope I don't have to swap this clutch out
    • hopeful
      • Dec 2012
      • 118
      So... what did you end up finding/ doing?
