Help with Carsoft?
    Help with Carsoft?
    Trying to do some programming on my E39 and figured it would be handy to have the capability to have the software, so I took the plunge and bought Carsoft V12 from the manufacturer. The software and hardware arrived and then realized I needed a serial port equipped Windows PC (have not owned a PC since 2005), so I bought a 2014-ish Panasonic Toughbook.
    Installed the software (per the directions that came with Carsoft) and I keep getting "dongle not found" errors. Nothing works with either the 20 pin round connector, or the OBD2 style connector.
    Machine is a CF-53 Toughbook on Windows 7, which the label says is Carsoft compatible.
    Has anyone here had any experience with Carsoft and could maybe walk me through what the issue may be/what I'm doing wrong?
    Many thanks.
    Autobahn Motorsport - Portland, Oregon - restoration + service
    @autobahnmotorsport
    '88 M5 | '89 330is
    No carsoft but I might be able to help. Update drivers on pc. Found in Control Panel -> Device Manager under Ports (COM & LPT) as well as USB drivers. Also...program could be looking for an actual dongle as per the popup. See pic. Sent from my Pixel 2 XL using Tapatalk
    "It wouldn't be there if it wasn't..." - Milton Berle
    1988 325iS - M20
      Updated the drivers to no avail. This particular program requires a constant 12v, which the USB to serial adapters won't work with, as they only give off 6v or so. Believe me, I wish it were that easy :/
      @autobahnmotorsport
      '88 M5 | '89 330is
        https://www.raspberrypi.org/forums/v...c.php?t=123165 Give this a read!!!! Sent from my Pixel 2 XL using Tapatalk
        1988 325iS - M20
