Eta coolant sensors
  • ethree
    • Aug 2007
    • 1216
    Eta coolant sensors
    In the side of the radiator I have two sensors. One has three wires connected to a red sensor, the other has two wires connected to a white sensor, is this correct? Am I correct in thinking the two wire is the auxillary fan switch? I need to ID these because for the time being I can only run one. Which one should I pick?
    Edit: car is an m/o 1986 325e built 01/1986.
    Those are thermo switches for the aux fan. They aren't needed if you don't have or aren't using AC.
