Car in question is a 91 325i Spec E30 race car...Gutted and caged, as you would expect. I just swapped in a fresh motor and was half asleep when I wired my starter the first go around and believe I have fried my ignition switch as a result.
Initially I was thinking I seized the starter solenoid (in my initial wiring I managed to get a wire on the lug the ground strap is on and tried to crank it that way, which resulted in the starter spinning for a moment and then quickly stopping...don`t ask, it had been a long day
), but just swapped in a brand new bosch solenoid and have the same issue...That is, no starting or cranking when I turn the key however I can start the car from the diagnostic port (shorting pin 11 and 14. I am still hunting down to make certain I don`t have a wire break somewhere in the ignition line, but my initial test at the C101 suggests the fault is definitely on that side (not getting any voltage between pin 18 and ground when I try to start the car).
Sadly, I have track time in a day so I won`t have time to correctly fix this with a new ignition switch. Is there a simple way that I can circumvent the ignition switch in the cabin so that I can start without assistance?
I suppose I could rig up some long extensions from the diagnostic plug into the cabin, but that seems like I am overcomplicating it?
tldr: Have a track time in a day and need advice (No matter how janky) on how to quickly be able to start a racecar without using the ignition switch due to it being busted/faulty and not having time to get a new one in and replaced.
