Unable to find the correct P/N for hose
  • j-e30
    • Jun 2020
    • 38
    Hi Everyone Does anyone know whats the PN for this hose ? I've looked at the M20B25 engine diagram and cant seem to find it anywhere.
    Thanks in advanced!
    Parts Catalog used
  • ForcedFirebird
    • Feb 2007
    • 8300
    13541719967
    https://www.realoem.com/bmw/enUS/sho...diagId=11_1167
    #18 and #19
    john@m20guru.com
    Links:
    • j-e30
      • Jun 2020
      • 38
      Would this hose be due to the bypass of the throttle body ? I got the car without those lines installed on the throttle body
      • ForcedFirebird
        • Feb 2007
        • 8300
        Actually, that's late model, if you have a <1988 you need:
        13541705568
        13541289976
        https://www.realoem.com/bmw/enUS/sho...diagId=11_1168
        #14 and #15
        john@m20guru.com
        Links:
        • ForcedFirebird
          • Feb 2007
          • 8300
          The TB can be bypassed with no ill effect. A short piece of plugged hose at the thermostat housing, and the nipple on the back of the block can be replaced with an oil drain plug and washer.
          john@m20guru.com
          Links:
          • j-e30
            • Jun 2020
            • 38
            hmmm now im wondering if the port on the back of the block being connected back to the thermostat housing be the reason why my car runs slightly cooler than normal. At this point i feel like leaving the current setup would be the smartest thing to do.
            • ForcedFirebird
              • Feb 2007
              • 8300
              Doubt it. On the race cars we block both those ports, as well as the one on the back of the head and have never had any issues with cooling. More than likely, your thermostat is sticky/missing, or has a too low temp stat.
              john@m20guru.com
              Links:
              • j-e30
                • Jun 2020
                • 38
                I guess ill be removing that hose and blocking the ports then! I was trying to change the hose anyways but now that i dont have to reinstall it ill just block the ports then!
                Thanks for the info!!
                • fitswell
                  • Nov 2008
                  • 224
                  that engine block port is a great place to install a sender for a digital water temperature gauge. less wire to run and won't need to mess around with drilling holes into the thermostat housing.
                  01.5 S4 Avant - Sold
                  88 325iS - In pieces
                  91 e34 - Totaled by some dumbass
                  90 325i - Daily
                  06 e91 - Sold
                  feedback thread
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Or an m20 oil pressure switch to warn low coolant pressure in a race car. ;)
                    john@m20guru.com
                    Links:
