What the F*#K is wrong with my e30??
  • =======Live Fast!
    • Nov 2011
    • 248
    Hey guys. Hope everyone's been well. Haven't been on here in a hot min. Here's the deal. I'm getting a stutter/bogging in the acceleration under load starting at around 3800 rpm and up. Not so much in 1st through 3rd. Very noticeable in 4th and 5th Haven't driven the car in forever as I was building an engine for it to go back in but am recalling that it was doing this before as well. This is what I've went through so far.
    New plugs, wires, cap and rotor. Checked the coil, good. Swapped out a known working afm, did't help. Swapped out a TPS today. Isn't that either. New injectors, new fuel filter. Wasn't that either. Last thing would be the pump and that covers fuel. It has new fuel lines as well and new hoses on the whole engine so no vacuum leaks. My buddy is thinking maybe it's the harness. Any thoughts? I've read other posts that seem to cover the same topic but never get resolved. This is making my head and my pockets hurt.
    sigpic2000 323ci
    1987 325is super etta
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
  • zwill23
    • Jul 2015
    • 615
    Sounds to me like a CPS problem. That issue is particularly common when converting to megasquirt, but it impacts the stock ecu similarly.
    • =======Live Fast!
      • Nov 2011
      • 248
      Brand new crank position sensor.
      sigpic2000 323ci
      1988 M5
      2000 M5
      1989 944 turbo
      1989 325is
      • lukeADE335i
        • Apr 2013
        • 1389
        With all that replaced, check the C191 connector under the inlet manifold - you might find the terminals are corroded.
        With all the injector & sensor changes etc. have you reset the DME so it deletes all error codes and goes back to base maps? If not, give that a try - when I swapped my CPS last weekend, the car wouldn't run right until I reset the DME as it had been compensating for the CPS being on the way out.
        Failing that, swap the DME for a known good one.
        Reading your post above - you mention the fuel pump as the last thing, I presume you've replaced it?
        My e30: OEM+ with M30B35
        • =======Live Fast!
          • Nov 2011
          • 248
          I haven't swapped the fuel pump yet. I'm going to swap the DME today and see what happens. Interesting thing about C191...Mine was hardwired in at some point so you might be onto something. Thanks for the info.
          sigpic2000 323ci
          1988 M5
          2000 M5
          1989 944 turbo
          1989 325is
          • =======Live Fast!
            • Nov 2011
            • 248
            Swapped the DME...not that either
            sigpic2000 323ci
            1988 M5
            2000 M5
            1989 944 turbo
            1989 325is
            • ZeKahr
              • Jul 2016
              • 508
              O2 sensor?
              1986 325e Schwarz (sold)
              1989 325iX Alpineweiß​ (daily)
              Greed is Good
              • lukeADE335i
                • Apr 2013
                • 1389
                Sounds like the electrics are pretty sorted (assuming the C191 is ok - check that the joints there aren't corroded / have bad contacts), you can check the O2 sensor by unplugging it, the car should run ok, just a bit rich.
                I'd give the fuel side some attention now. Could be a leaking Fuel Pressure Regulator, but I'd think the most likely culprit is the fuel pump.
                • twright
                  • 707
                  Put a fuel pressure gage on the line going to the injector rail. See if the pressure drops when the "stuttering" occurs.
                  • =======Live Fast!
                    • Nov 2011
                    • 248
                    Just swapped out the fuel pump with a good one...wasn't it. Unplugged the O2 to run it and it's still doing it. I'm going to try a new crank position sensor tomorrow and I'll report back.
                    sigpic2000 323ci
                    1988 M5
                    2000 M5
                    1989 944 turbo
                    1989 325is
                    • Khoronzy
                      • Jun 2016
                      • 9
                      Check that the bottom of the rubber inlet isn't torn between afm and tb. It tears where u can not see it. And if u just look u won't see it.. take it off and look!
                      • peytonracer4
                        • May 2011
                        • 524
                        you're sure the timing belt isn't off by a notch maybe? unlikely, but just brainstorming.
                        • =======Live Fast!
                          • Nov 2011
                          • 248
                          New crank position sensor today just to make sure...not it. And Peytoracer4 this had been happening on my last 3 engines I had in there. Also it was a symptom that used to only present itself at higher rpm and gears and now it's lower gears and rpms. The wiring harness is literally the last thing that could be done.
                          sigpic2000 323ci
                          1988 M5
                          2000 M5
                          1989 944 turbo
                          1989 325is
                          • lukeADE335i
                            • Apr 2013
                            • 1389
                            Hi Live Fast! Did you end up sorting your issue? Just interested if you managed to resolve it after swapping so many parts.
                            • E30 Wagen
                              • Jul 2005
                              • 3434
                              Maybe back pressure from a clogged exhaust system?
                              My Feedback
