Raising My M20?
  • ThomasE30
    • Mar 2020
    • 104
    Raising My M20?
    So I cracked my oilpan a month ago and did the swap with my e36 rack i put in and i'm worried it might happen again so i bought a Red46 skid plate. This cannot go on rn as the radiator core support started to rust and bend so the plate doesn't reach the core support. I am going to have someone cut out the bad part of the support and weld on a piece to fix it. Would there also be a way to raise the engine as another way of protecting it? I've seen people say they have put washers, made their own custom motor mounts, or even use hockey pucks. would putting in washers help to raise it so it's higher off the ground? And would I also have to put the same amount of washers on the tranny mounts? Would this create any noticeably louder sounds or make it feel bad while driving? Thank you!
  • Zambuzan
    • Nov 2017
    • 434
    Changing the driveline angle without further compensation is problematic. The driveshaft U-joints will compensate but only up to a certain point.
    You might be able to get away with installing a few thick washers on the underside of the mounts, but obviously this is only avoiding the problem (instead of being a solution). Take care to note hood and firewall clearance if you choose to do this.
    I would also drive really carefully around town (I'm assuming you're dunked on the ground).
    Good luck!
    "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
    • Gus
      • Jan 2004
      • 285
      Easiest solution seems to be to stiffen the suspension/raise it? I rarely have clearance issues and drive pretty much everywhere
      JUNGL3
      1990 "333i" Sport
      • roguetoaster
        Biggus Tippus
        • 7829
        This sounds more like an issue with the nut behind the wheel. Adjust that and you'll be fine.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5480
          fix the support and use the plate.
          don't raise the engine.
          • tomstin
            • Mar 2015
            • 562
            Seems strange having clearance issues if it is stock. Agree on fixing the core support first and use the skid plate. DON'T raise the engine, it will play havoc with the drive line geometry. Seems like there has to be more to the story. Small, low profile tires? Lowering springs?
            2004 525i Manual - 1985 325E Coupe Manual
            • rturbo 930
              • Dec 2005
              • 2615
              Raise the car to a reasonable height. My car is lowered, and I've never scraped on anything.
              • ThomasE30
                • Mar 2020
                • 104
                Good luck!
                It used to be dunked on the ground with cut coils but i took care of that. I should've put the sport oe springs on from HR but i did just the sports. Doesn't sit as low as it did but still worries me a little. Thank you though. I think my best option is just getting the issue with the skid plate over with.
                • ThomasE30
                  • Mar 2020
                  • 104
                  yeah that seems to be the best bet. thanks! And it's not stock. It used to be on the fucking ground but now it's just lowered reasonably. In the back of my mind i just keep replaying how much time it would take to do the oil pan again which scares me more than anything lol
