Engine block heater for E30’s
  • mach schnell
    • Apr 2008
    • 1059
    Anyone have a functional block heater that they use or can suggest? Gets cold where I live.
  • roguetoaster
    Biggus Tippus
    • 7829
    Likely that Kats will be your best, most readily available option. Freeze plug install, thread ins (coolant or oil side), magnetic, and in hose heaters all work fine. There was a dealer option heater, but I can't find any info on it with a quick search.
    • mach schnell
      • Apr 2008
      • 1059
      I prefer something thread in over magnetic or adhesive. Where can I thread one in? Is there a specific location on an M20?
      • roguetoaster
        Biggus Tippus
        • 7829
        Block drain is the only thread in position I know of, and you'd likely want to look for a diesel block heater for a thread in application. However, it may just be easier to get one that splices in to a heater hose, and it would make routing the plug a little easier.
        The only one I have personally installed was on a VW diesel that went in to a freeze plug, but it was a bit frustrating to fit.
        • dstevenson
          • Oct 2020
          • 11
          The easiest solution would be to splice a universal automotive heating coil into bottom radiator hose. Be forewarned these devices use a lot of electricity.
