In tank low pressure lift pump replacement
  • bradmer
    • May 2016
    • 389
    Is there a diy with a low pressure pump part number to replace the OEM lp pump on the bracket inside the fuel tank? The only lp pump I see online includes the bracket and is over $500. The high pressure one for the late model looks the same and is $140.(?)
    I have read on the web that there are low pressure pumps out there (non BMW) that will work but have not seen any part numbers. The BMW part number that I am referring to is 16141179415 off realoem for up to 9/1987 325i.
    Hoping someone can post up a pump part number with the correct size/flow rate/voltage that I can wire up to the bracket and drop back in. I plan on cleaning the bracket and suction thingy to reuse.
    I have a 2/87 build date s52 car with a fuel accumulator for track days, so I would rather keep the setup as is than move to a single pump system.
    Any help appreciated.
  • twright
    • 707
    Will this work?: https://www.amazon.com/Bapmic-161411.../dp/B01N9MCPMP
    • bradmer
      • May 2016
      • 389
      Possibly, I'm unable to determine if it is the low pressure unit from the information they have provided online and have asked them for clarification. Thanks for posting that up.
      • bradmer
        • May 2016
        • 389
        Anyone?
        Somebody must've come up against this by now unless the pumps went from $140 to $500 overnight?
        Sill searching for a lp pump part number and a link.
        Thank you in advance.
