Head Light issue
  • HVDE30
    • Jan 2021
    • 11
    Head Light issue
    Hello all, Nub here. I have a 1990 325i 4dr and the low beams do not come when I turn them on, but come when I turn on high beams they come on same as fog lights. Also the tail light running light stays on when battery is hooked up.
  • roguetoaster
    Biggus Tippus
    • 7814
    Can you adjust your cluster/dash light brightness? I ask as it sounds like a bad or corroded switch. Might be useful to probe it with a meter.
    • cheffy30
      • Sep 2016
      • 1159
      check fuses and relays and bulbs sent from hell using Tapatalk
      '90 325i sedan daily driven
      '85 325e coupe also a daily
      • Gregs///M
        • Mar 2012
        • 2459
        The dimmer/headlight switches commonly fail, I would suspect that first. Try cleaning the contact very well or swap with a known good part.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
