A/C Compressor Black wire
  • Westija
    • Aug 2015
    • 90
    After finishing my T Belt and Radiator Hose changes (and other stuff), I realized I might have disconnected this black wire that comes from the top of the A/C Compressor. Does anyone where this is supposed to be connected? The A/C has been converted to R134 by the previous owner, so I am not sure this is the original wiring. When trying to find it using the schematics (not my cup of tea) the only black wire I see is connecting the High and Low Pressure Cut-Out Switches.
  • tomstin
    • Mar 2015
    • 564
    My dryer is right behind the headlight bucket. I don't see yours in the picture. As I recall, there was a Technical Service Bulletin on the R134 conversions where you connected the low pressure cutoff to another wire. I can't see to find where that TSB is now. Does your AC compressor come on?
    2004 525i Manual - 1985 325E Coupe Manual
    • Westija
      • Aug 2015
      • 90
      I looked at it again and found a connector that the wore fits to. It seems it was part of the conversion. Now I have to find the R134 leak: once charged, it works for a few days, but then the gas leaks and does not.
      • tomstin
        • Mar 2015
        • 564
        A good reference is Bob Siegel’s book “only needs a recharge”. Worthwhile investment if you want to work on AC.
