e30 M sounds like engine undergoing dry starts every so often
  • ethirtydavid
    • Jan 2008
    • 2331
    Castrol GTX 20w-50
    Initially I thought it was an issue I noticed when parking on hills then recently it has happened a couple times while parked in my flat garage.
    9/10 times it starts fine and no issues.
    1/10 times it sounds like a dry start issue, somewhat loud and lasts for about 6-10 seconds (assuming this may have something to do with recirculating fresh oil to the cylinders).
    Doing full oil change tomorrow to see if this changes symptoms, was curious if anyone here had heard of these issues with their engines- or if this could be something specific to s14.
    I'll be running some tests this next few days, curious what ya guys think-
    thanks
  • Hey_You
    • Nov 2009
    • 963
    This used to happen to my m10 fairly frequent. Make sure you use a good filter to help reduce drainback.
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
    • Todd Black 88
      • Oct 2007
      • 3449
      Sounds like a tensioner failing, if you are still using the original style. It uses oil pressure to tension the rail on the timing chain and can take a few seconds to pump up enough to quiet the chain.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • reelizmpro
        • 9558
        Two things to make sure you have...proper oil level and good chain tensioner.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • ethirtydavid
          • Jan 2008
          • 2331
          excellent, loving the feedback-
          I will verify proper oil level and new fluids tomorrow and if issue persists I will move forward on replacing the chain tensioner.
          • e30s50dan
            • Nov 2008
            • 2076
            ^^^ this
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • 17sd
              • 158
              chain tensioner
              Should the tensioner be changed to the E36 unit?
              Can anyone provide a part number for me?
              Thanks.
              • ethirtydavid
                • Jan 2008
                • 2331
                Thanks.
                p/n 11 31 1 405 081
                more info here for use of e36 M tensioner on s14:
                • chucker
                  • Jan 2009
                  • 106
                  Chain tensioner without a doubt. chucker
                  89 M3 "Ms. Bavaria" Garage Queen Cinnabar w/ black guts
                  12 Chevy Avalanche "OJ" Black on Black and.... Loaded
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    I just installed a new 95m3 unit...very happy. No more diesel noise when started.:D
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • ethirtydavid
                      • Jan 2008
                      • 2331
                      installed p/n 11 31 1 405 081, s50 tensioner.
                      chain tight, noise gone- issue solved.
                      • mikeedler
                        • 6707
                        also don't park the car with it in gear on a hill- it will stress the chain a bit. yep, changed my tensioner about 9 years ago, never heard that noise again!
