I'm interested in seeing what you wind up doing for the brake booster.
E30 m3 ls1
Sub'd as I am considering doing this swap too.
My 1989 e30 s52 Touring... this is Betty
My 1989 325i vert (sold)...this is Nina
My 1991 M5 (sold)... this is Veronica
Photo comparison: OEM vs aftermarket windscreen for a convertibleComment
Non assisted brakes is not an option so I will be using a hydroboost system utilizing the bracket provided in this kit. If I figure out an assisted brake at a later time that does without this braket, then I will remove it. Right now it seems that it is the best solution. I'll provide a review on the kit as a whole when it arrives.
cai, exhaust, ls6 cam, heads, intake manifold and tune should yield 400hp fairly easily. Drivetrain is a 99' w/ 67k miles.Comment
sub'd.
「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
「my feedback thread」Comment
the local LS7 e30M I built a diff for fitted the ford hydroboost unit from the garret tvs kit. it barely clears the front apron but does fit in reasonably clean.
the driver side strut tower needs to be scalloped (and re-inforced)OBD1 M54/M52TU swap as a M50b25
