E30 m3 ls1
  • LSM3
    • May 2012
    • 340
    #31
    So I kind of took a step backwards this week. After futher inspection of the interior of my car, more rust was found. So the decision was made to get the whole body media blasted and a baked on primer applied. This thing just turned into a complete resto-mod.
    • garretvs
      • 464
      #32
      Originally posted by 10Toes
      I would use the massive boosterless setup, the hydro boost/linkage setup looks like shit and takes up a lot of room.
      So what do you know about brake boosters?? No booster means a lot of pedal pressure; the flimsy seatback mechanism can't take it for very long.
      E30-LS1 aka. 357is
      email us to pick up our LS1 swap guide
      E30-LS1 KITS now available!!
      E30LS1@gmail.com
      e30ls1.com
      • Jean
        • 18228
        #33
        No booster does not necessarily mean stiff pedal if the pedal ratio is good and correct mc is used though...aka tilton/wilwood configs.
        • Teaguer
          • Sep 2004
          • 6167
          #34
          Nice. Subscribed.
          • Jason89i
            • Sep 2004
            • 875
            #35
            not entirely true.
            provided the pedal lever ratio is 6.25:1, the pedal feels like a 25mm master on a boostered 4:1 ratio pedal.
            boostered pedals keep a 4:1 lever ratio.
            boosterless pedals should have a 6.25:1 lever ratio.
            i have not used the "massive" unit, but i have used his products and they are top notch. i would also assume it uses a 6.25:1 ratio.
            for reference:
            owned 15+ e30's, a few converted (m50, m50tu, s52, s50b32, s54 .... now ls2)
            built, daily driven, tracked and logged over 50k miles. used multiple brake system combinations.
            • LSM3
              • May 2012
              • 340
              #36
              Originally posted by Jason89i
              not entirely true.
              for reference:
              Does retaining the ABS change this in any way?
              • kalib0y
                • Dec 2004
                • 3620
                #37
                very nice! I approve. This thing is going to be a beast!
                95 7.1L 16V E36 M3
                Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                LIKE my Facebook Page! CLICK HERE
                • Jean
                  • 18228
                  #38
                  not entirely true.
                  for reference:
                  Thanks, exactly what I meant above :)
                  • LSM3
                    • May 2012
                    • 340
                    #39
                    Christmas in June!
                    Bilstein Sports
                    H&R Race Springs
                    Stainless Brake Lines
                    Control Arms
                    S/T Sway Bars
                    Front/Rear Sway Bar Links
                    Tie Rods
                    Strut/Shock Mounting Kits
                    Rubber Strut Mounts
                    (4) Brake Caliper Rebuild Kits
                    Subframe Bushing (OEM)
                    Rear Trailing Arm Bushings (OEM)
                    Front Control Arm Bushings (OEM)
                    Still Waiting for:
                    Z3 Steering Rack
                    LS1 Kit
                    • BillBrasky
                      • Dec 2008
                      • 1641
                      #40
                      Nice. I'm assuming that you've seen the LS3 that Kevin Byrd put in his M3 on Two Guys Garage. I bought the s14 out of this car off of him a few months ago.
                      • LSM3
                        • May 2012
                        • 340
                        #41
                        Ive seen the previews but I cannot find the full episodes anywhere. :-(
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #42
                          is there a link where we can get details of that build?
                          • airkhin
                            • 593
                            #43
                            looking forward to seeing the build thread. this thing is a beast! it was nice meeting you. ;)
                            • LSM3
                              • May 2012
                              • 340
                              #44
                              Nice meeting you as well.
                              • MattAvino
                                • Jan 2011
                                • 2147
                                #45
                                I saw one episode with this m3 in it. I must see more!
                                E30 buildy things
                                http://www.r3vlimited.com/board/showthread.php?t=195286
