Sweet work as usual - and digging the new handle too lol.
The 5 Year Restoration - E30 M3 Reborn
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts. -
Thanks. I got into the fuel tank. Great news there - no rust! I may still have it cleaned, but it should be good to go with some new lines
Sent from my iPhone using TapatalkComment
Got another quick question for you. I bought this part after reading a post here at some point
https://www.ecstuning.com/Search/Sit...h/51481916442/
My question is, do I need to get the other two (L and R) parts next to it in realoem? I cant tell if those L and R parts are for the engine bay too, or if they go under the dash in the interior.
01 SOUND INSULAT.DASH PANEL ENGINE ROOM CE.
01 SOUND INSULAT.DASH PANEL ENGINE ROOM L.
01 SOUND INSULAT.DASH PANEL ENGINE ROOM R.
http://www.realoem.com/bmw/enUS/show...diagId=51_1827
Appreciate the help.Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3Comment
Two Years In... M3 Build Thread...Now in Paint!
The one you bought goes in the center and down into the transmission tunnel. Its not as big on the sides as it looks on Real OEM. the other two part numbers go on the driver's side (behind the fuse box) and the passenger side (behind the coolant overflow reservoir). I am replacing all three. :up:
Edit: All three are in the engine bayLast edited by CurrusDei; 07-27-2016, 08:06 AM.Comment
Ok, thats what I thought. Thank god those insulation pieces are still available...will definitely be replacing them whenever I decide to pull my motor :)The one you bought goes in the center and down into the transmission tunnel. Its not as big on the sides as it looks on Real OEM. the other two part numbers go on the driver's side (behind the fuse box) and the passenger side (behind the coolant overflow reservoir). I am replacing all three. :up:
Edit: All three are in the engine bayCurrent:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3Comment
Seats coming apart!
That's where I stopped because I didn't have a set of snap ring pliers-old set broke. I called ECS about returning a brake bleeder wrench that didn't fit in exchange for some snap ring pliers that were the same price. They told me they'd just send me the pliers and not to worry about returning the wrench :-O
Also, had a long talk with Furniture Clinic. All of this is on the way. I have high expectations.
Leatherique works very well. The sanding and crack filling part doesn't last unfortunately - maybe a couple of seasons wear before it starts cracking again.
Those seat backs look to be in terrific condition..I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
I've seen a lot of instances of leatherique peeling, but have heard a lot of good stories about furniture clinic's stuff being very durable. The dye is supposed to penetrate down into the leather instead of being a top coat. We shall see. The seats are in ok shape, those pics are a little poorly lit...
nice! How'd you find it?Comment
Apparently the part is not found on m3s originally. Its a very early e30 m20/m21 part but works well for our cars as well. I do not like the clips the m3 uses. Not to mention, my car is missing 1 of the 2 little studs that hold them.
The proper clips, which look like this:
And you wedge them inbetween these little studs
Current:
1989 325i
1988 M3
1987 325ic
Past:
2001 330ci
2001 M3Comment
Interesting. I'll keep in mind in case some of mine break or disappear
Underside review before deciding how to proceed. Decided to clean up, keep original where it is in good shape, redo undercoating in a few areas with cuts/abrasions so that it is watertight, undercoat will stay oem tan with red overtop (in an oem style pattern, which is less than 100%, paint coverage). Wheel wells will be black.
Look at that primer line for the windshield epoxy. That's why the right body shop matters. The guys at Magnum did this without me even having to ask - they know that the primer is a better surface for the windshield epoxy bond than paint would be. Very cool.
