The 5 Year Restoration - E30 M3 Reborn
    i know what you mean re fasteners. Jordan's recent resto-mod had a link to an outfit in Texas that still does this work. Would be great if it could be done safely and inexpensively at home..
    Link to that DIY zinc chromate page?
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
      Yeh the problem with sending them off is they're all bagged and tagged. A plater will want to do them all in one go, and I would bet they wont come back as organized as they went out.
      Links:
      _______________________________________________
      5 Year M3 Build, In Progress
      RMT200 Retrofit
        2.5 Years In... M3 Build Thread...PAINT COMPLETE!
        Some fresh paint
        Tape off of the bumper mounts
        Gas lid lock painted and back in
        RMT200 Retrofit
          Back she goes
          RMT200 Retrofit
            Curious how the diy plating thing works out.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
              This build is bonkers. Love it!
              2007 Big Twin Turbo 335i + 1989 E30 Track Car
                Nice work. Home plating can be done with good results. Have a look here.
                  http://vwgolfmk1.org.uk/forum/index....gine-detailing
                  Geeez! A build after my own heart. Will use this.
                  RMT200 Retrofit
                    Caswell kit inbound. 1.5 gal with yellow chromate
                    Also purchased this power supply. 30v 10amp (vs the vw 20v 5amp) because I'm doing some larger parts, and because more power.
                    I also re-sorted my hardware tonight. Fun fact. Everything on this car is yellow zinc. These things must have looked insane when new. Box is yellow/gold, bags are silver, mixed (mostly gold), and black. Most of my other hardware boxes are empty now.
                    Also added
                    Zinc Blackener
                    Benchtop Buffer
                    Various pads and compounds
                    And picked up some more abrasives and muriatic acid. The lab is coming together
                    RMT200 Retrofit
                      Ive been looking at part tumblers recently too....seems like that would go well with a plating kit.
                      Current:
                      1989 325i
                      1988 M3
                      1987 325ic
                      Past:
                      2001 330ci
                      2001 M3
                        Yes it would. I almost bought one, but I'm going to see what the acid and degreaser does first. Harbor Freight has some inexpensive ones
                        RMT200 Retrofit
                          Sanding and priming. Not everything is being primed, only parts like the sunroof runner that had some rust bubbles and were taken down to bare shiny metal
                          Everything in the bottom right is ready for paint. Fun fact, the tiny pieces between the primed sunroof runners and the B pillar covers...cost $80 new, a piece.
                          RMT200 Retrofit
                            hi
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
                              Hey, sorry been busy lately. Car's still at the body shop and I haven't been pushing them on it because I'm doing some work in the garage that is not awesome for new paintwork to be around. Lots of chemicals and spray painting. Even with proper precautions there's only so much you can prevent. That said, here are some pics from recent work...
                              Harbor Freight 5lb vibratory bowl
                              Rust removing media
                              Shredded walnuts. After reading a lot this was a well reviewed media and it's actually pretty cheap - because it is sold as iguana bedding. True story.
                              Some before/after
                              Tumble/Sand/Paint
                              The bowl is a great tool, but it's not magic, and not as good as a media blaster. It won't take off anything greasy with the media I'm using, so I'm using a combination of chemical soaks, brushes, sanding, an ultrasonic cleaner, and the tumbler.
                              This was an interesting piece
                              These wire mesh gaskets didn't seem good to tumble, so just brush and ultrasonic here. They were caked in oil at first.
                              The lower part here really responded to tumbling. The top one not so much, probably because it has spent its life ON the exhaust manifold, so it's been reeealy hot and is thus pitted a lot from debris baking in.
                              It did respond to an overnight soak in a rust removal solution I got at HF
                              Front sway bar mount. One tumbled about 2 hours, the other not.
                              Misc hardware. You can see the 6 brake line brackets in the upper right that 4 were scrubbed before being tumbled, 2 were not and are going back through the process now
                              Also had to use my punches and mallet to beat this trim piece corner straight. Came out well.
                              My DIY paint booth
                              So far (actually there's more drying in the garage now)...
                              For the parts cleaning, my method is going to be
                              Degrease if needed
                              Tumble
                              ...continue until ready for
                              Benchtop Polisher
                              Acid bath or electro de-plating to remove old yellow zinc coating
                              New Zinc Electroplate
                              Yellow or Black Zinc Coloring to match oem
                              Off to put on another coat of paint...More to come
                              Edit: here's where I ended the night
                              And with flash on
                              Plus other flat door trim and both door handles in primer and drying
                              RMT200 Retrofit
                                Looking good man :)
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
