Originally posted by MyE30
View Post
The 5 Year Restoration - E30 M3 Reborn
Brief update, but more to come shortly. I'm going to finish this thing in short order. Motor start looks like this month, want it done by May beacuse 5 years is long enough
Headlights arrived. Very much worth the wait.
manual adjustment knob
wires are inbound. have to re-wire to eurospec.
New coolant cap
Final hose - power steering pump to rack. The new versions are slimmer than the old
Fitting shape is also different. I think this will still work, but we'll see
I connected it up first, then had to undo it to fit in the steering u-joint. so, do the u-joint first, then the final line
u-joint. top was easy to get on. the bottom wasnt. had to remove the bottom bolt (of course, wont go on with it on), line it up, and have my wife hammer on a bunch of socket extensions that were connected together and rested on the top of the lower section of the u-joint. it gradually went on, but was definitely a 2 man job to keep it aligned while hammering from the top.
Got the throttle cables on
Also, I had some degraded wiring connections. Found a good permanent fix...
Coolant level sensor: Original wires in my hand, BMW replacements hooked onto the sensor
Thermostat sensor connector: This one was a real beauty. Nice fix by the PO soldering rusted wires.
Here's my fix. Of course you can just connect up the BMW replacement wires, but then you're left with just green wires and no way to tell which is which. My solution was to order the colored tabs in the picture below, along with clear heat shrink wrap.
I cut sections of the color labels corresponding to the OEM wire color, wrapped them around the end of the wire, then used the clear heat shrink to encase it, so that whenever I need to know which wire is which, its right there
Also, I switched to these instead of soldering or using crimp connectors. These things are awesome.
Also, critically, Raychem DR-25 heat shrink wrapping is far and away the best I've found. It stays flexible after shrinking where many get stiff and brittle
Coolant level sensor repair:
Thermostat connector repair
Other sensor
T-stat in
Also, I decided against the DSSR. Went with the factory one.
First fitting had a lot of slack.
Used more to close the gap per recommendations from other owners
Brakes
Disassembled the calipers. Messy job. had to use a grease gun to push the old pistons out.
I tried cleaning them up a bit, but it wasnt happening. Sent them off to be zinc coated. I can not wait to get these back and on.
Originally posted by iliad View PostIncredible work!
Just read through the whole thread.
Hope to see this beauty at The Vintage this year!
I'm running full speed to finish her up. Been getting a lot of boxes lately. I spent my free time this weekend with degreaser and a pressure washer cleaning off the underside. Very dirty job, but i decided i couldnt leave the underside dirty when the rest of the car was so clean. I'm using an engine degreaser gel, and just got a short handle for my pressure washer. Thankfully temps this weekend will be warm so i can finish that part up and start the driveshaft/heat shielding work
Remaining to be installed- Headlights (have)
- Brakes (in mail this week)
- Gauge restoration (going to Bavrest right after the motor starts up - hopefully this weekend if the brakes come in)
- Drive shaft (have)
- Front/Rear Glass (have)
- Heat shielding/underbody trim (have)
- Rear bumper trim behind wheels (in paint)
- Midsection (in mail)
- Evo 3 muffler (in mail)
- AC system (last parts arriving today)
- Bumper (complete, just need to mount)
- Evo Bumper and Hood seals (have)
- A few remaining factory decals (have)
- Spare wheel/tire (need)
- Dash/wiring (have, testing electrics before installing)
- M3 door seals (still off because of electrical testing)
- Door film (in mail - off for electrical testing)
- New Switches (in mail)
- E36 hand brake cover (in mail)
- Steering fluid (trans fluid, diff fluid, coolant are in)
- Badges
- A few other things im sure I'm forgetting
Will post update soonLast edited by CurrusDei; 03-06-2019, 09:08 AM.
You’re a mad man... I’m so impressed by everything in this thread.
Have you ever restored a vehicle before? How are you confident that you’re not missing a step or doing something incorrectly?
I love the work you’re doing!JP
WTB: Z3 1.9 lever, plastic bumpers, 19# injectors, Anthracite Cloth Sport Seats
Current
88 325 super eta
00 528i/5 (daily)
02 530iA sport
Former
04 525iA sport
87 325is
91 325i
97 528i
Originally posted by AC_Schnitzel View PostYou’re a mad man... I’m so impressed by everything in this thread.
Thanks!
No, first time
Go slow, research what others have done, think through details, take 10,000 pics, know my limits, ask for input, fix something if I break it (no big issues yet - worst thing was stripping a thread for the rear ABS and having to re-tap)
Thanks!
Seriously it’s a function of time, thought, and teamwork. The guys at Korman have been invaluable, as was my body shop, as was my interior guy, as has R3V/S14/RealOEM/FCP/Bentley/old factory manuals and on and onLast edited by CurrusDei; 03-06-2019, 08:17 PM.
Lot going on. Working on the car whenever i have a free minute so no time to post updates. Pics will follow once i have the car off to the glass, exhaust, ac, other guys, but quickly:
Car is registered for the Vintage. It starts on my birthday this year, so that had to be my finish line.
All AC hardware installed (specialty shop will have to charge and make the connections at the compressor work, may require some hose customization). Everything is new except one line that was NLA, and I had it cleaned by a specialty AC shop
Dash in
Radio/controls in
All electricals work - everything. no shorts or other gremlins to chase
New signal stalk, refreshed cruise control and wiper stalk
New sunroof motor in (works)
Gauges restored by BavRest and installed
center console in
Shifter cover in
Door vapor barrier in
Door cards in
///M Door sill covers in
B pillar covers in
engine wiring covers in
New fuse box cover in
Euro elipsoid smileys in with new euro connectors(4 bulb high beams function, city lights wired)
Front grilles (all 3) in
Front sway bar in
New Bosch battery with OEM vent in
New drive shaft center support bearing installed
New drive shaft guide bushing installed (this was a pain)
To do
Rear reflectors: should arrive tonight, putting in this evening hopefully
Rear sway bar: in this evening hopefully
Drive shaft: rear half is in. I bought the wrong size guibo, new one gets here tomorrow. Drive shaft should be done tomorrow night, then bolt up the front control arm lollipops and it should spend its first night on its own tires in about half a decade.
Glass: Have all the glass and found an expert shop to do it (they have done several E30 M3 restorations). The big glass guys all didn't want to touch it, and most hemmed and hawed about how the glass doesnt need to be glued in, they've done 5,000 of them so they know...blah blah. My only response was that there arent even 5k of these in the U.S. Anyways I'm hoping to get it to the glass shop late this week - open header, no windshield drive should be interesting
Underbody shields: I did some work with degreaser and a pressure sprayer to clean up the underside. Looking better. Will install heat shields tomorrow probably.
Hubs: Torque to spec when on ground, install lock nuts, center caps
Exhaust: Evo III muffler and VSR center in hand - going to have a really great welder put them on. I'll post some of his work once he confirms his availability, its weldporn level work. Contrast that to my old exhaust's welds, one of which has about a 1cm long stick weld section standing up out of it. Good metaphor for this whole process
Spare: Extra spare wheel should be here by tomorrow, getting it refurbished and putting on a new tire
Sunroof: waiting on two little rivets from Germany, then it will all go together. the rivets my upholstery shop used were too tall and wouldn't fit in the track. Putting the rivets in myself by hand, then it should all go together
Bumper: put it on
Body: Fine tune adjustment of hood/trunk/rear window to get even gaps. Install Evo hood gaskets
Ceramic/Film: Still considering here. There are some seriously talented ceramic coating and paint protection film guys in the area that I'm thinking about having do their "armored car" package on the car to protect it. Still undecided
My fingernails are pretty much always dirty these days. Also, fewer boxes of parts on the shelves. On the home stretch.
Originally posted by CurrusDei View PostCar is registered for the Vintage. It starts on my birthday this year, so that had to be my finish line..I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
