88 Evo 2 - $90K
  • markseven
    • Sep 2006
    • 5327
    88 Evo 2 - $90K
    Originally posted by 1988 BMW M3 EVO2 on eBay
    I know this will be a painful memory; but remember about 15 years ago when you could buy a 1973 Carrera RS for $45,000, or twice the price of a regular long-hood? And now the RS is worth $600,000 and a T is worth $60,000? Don't think of the BMW E30 M3 EVO2 as a car, think of it as a time machine which will allow you to make up for the buying decisions which rue your memory.
    There were 18,843 E30 M3s made. But only 500 EVO2s. An excellent 100,000 mile E30 M3 is a $45,000 car and this EV02 is vastly undervalued at $90,000. In 15 years the EVO2 is going to be worth $400,000, along with other medium priced 80s and 90s exotica like the Porsche 964RS and Audi Sport Quattro.
    Any one of the 18,843 production E30 M3s will draw thumbs upward. But there were simply too many to ever become precious. There were 1023 Aston Martin DB5s, 106 McLaren F1s, 970 Ferrari 275s, 1400 Mercedes Gullwings and 337 Porsche 959s. These are the benchmarks of collectibility and none of them would be worth a million-plus, if 19,000 of them were out there.
    To give another example, you can buy one of the 21,542 Alfa Romeo Sprint GTs made from 1963-1966 for $35,000. But if you want one of the 500 Sprint GTAs, homologated for racing, it will cost you $700,000. I was recently driven over a mountain road at 10/10ths and 8000 rpm in a GTA, that was purchased by its driver in the 80s for $6000. Don't you want to be that guy?
    Let’s discuss the EV02’s base car, the M3. I like everything about it, including the shape of the letters themselves. M stands for Motorsport, and the M3 was built to race. It is what the cognoscenti call a homologation car. Ho-mol-o-gation. In the 1980s, BMW wanted to win the DTM (Deutsche Tourenwagen Master) racing series. They needed a racing engine, wider wheels, stronger suspension, better brakes, quicker steering, close-ratio gearbox and aerodynamics to press the tourenwagen to the tarmac. In order to be considered a production car, 5000 examples had to be built. And build them they did, winning the World, European, British, Italian and German championships.
    The aesthetic effect of which transformed a Twiggy of a car into a Marilyn Monroe, with a voluptuous hourglass, and a rear spoiler that draws stares. And because the car is a homologation, the large flares and shapely rear end are natural, without any of the cheap perfume and burning rice of aftermarket body kits.
    Every year in racing there is an evolution of the cars as builders learn what wins and adapt the cars to do so. But these EVOlutionary changes require only 500 cars to qualify. There were three EVO M3s built in 1987, 1988 and 1989. The EVO1 is indistinguishable from a production M3 except for a slightly modified head that produces no additional power. The EVO2 is the Goldilocks of the range, with significant mechanical, aerodynamic and visual modifications. The EVO3 or Sport EVO is most valuable, with a 2.5 liter engine upgrade and 90s style seats and suede. In total, around 1500 EVOs were made. The EVO1 is for those who want to buy the name, the EVO2 is like a Carrera RS, and the Sport EVO is the Carrera RS Lightweight.
    An EVO2 looks even better than a Neanderthal M3. The front spoiler is noticeably extended. What it lacks in proportion it makes up for in distinction, like adding as ascot to already shapely neck. Brake ducts supplant foglights. The EVO2 wheels are Goldilocks plus-one 16s. Fifteens are runtish, and 17s stancish. A cammy, highly-compressed, freer-breathing engine painted white, red and blue. Headlight wipers like Cara Delevingne’s eyebrows. Tartan seats like a John Holmes’ kilt. A plaque to make you proud. And rear headrests to keep your kids from snapping their necks; because those smart enough to buy an EVO2 should propagate their genes.
    It not only looks, but drives better. Thinner glass and lighter bumpers and rear deck drop the weight a shruggish 22 pounds. But thinner glass is just cool. Every panel that reduces weight is EVO bespoke and therefore super-bitchin. If you are used to a U.S. M3 with sunroof and air-conditioning its like your wife returning from Canyon Ranch in sized down skinny jeans.
    So she is a bit lighter, and about 10 percent more powerful at 220 horsepower. Higher-compression pistons (11 vs 10.5), bigger cams (264 vs 248), stiffer valve springs, improved intake and little bit of chipping add 20 horsepower. Big deal, you may say. And sure, you could hotrod your M3, to go along with your SC powered Carrera RS replica. But it will never be an EVO2.
    The flywheel is lightened, which in terms of feel, makes as big a difference as the engine work. At idle it’s has a little more clatter, which combined with the lope of the cam, alerts your senses, like a Kudu hearing the purr of a Lion under a Serrenghetti moonrise. Because of the flywheel, the engine feels like its spinning up in zero-gravity field, rather than a vat of syrup. And once it comes on cam at 5000 rpm, it rips to 7300 with frenzied excitement.
    What’s more fun; galloping and jumping a whipped pony over a felled tree, or nonchalantly stepping over it in a Clydesdale? Over-tired, magnetorheological-damped, turbo-torque-boosted, stability-controlled, automatically-shifted sports cars are boring to drive unless you are on track with systems off. Keeping up with the car in front of you is a snoozer. But try keeping up with a Porsche 991 in an E30 M3, and you’ll be slotting a buzzy shifter, playing morse code with the redline, and steering with the vibrating accelerator. Heel-and-toe before the corner, keeping the engine on cam, with an entry speed high enough to chirp the front tires, snap the throttle and come out of the corner with a hint of opposite lock and rear wheels slipping their angle. Up ahead, the guy in the 991 is texting.
    For Americans, an additional benefit of the EVO2 lies under the right hand, which shifts a Getrag, close-ratio, dogleg gearbox. I like everything about that sentence. Getrag sounds like a the name of a dashing German Viscount. A close-ratio gearbox helps keep the peaky engine in its powerband during shifts, optimizes gear selection and allows the engine to reach redline in 5th gear. Dogleg gearboxes suck if you live in LA, but rule if you drive in the curves. Once you’re out of first, the most important shifts, second to third and back, are in a straight line. And a dogleg gearbox is inherently chic, unlike our hickish, wide-assed, easy-listening, elephant-leg of a gearbox, which leaves fifth gear out in set-it-and-forget-itstan.
    The brakes are the same as an M3, but are cooled by ducts where the fog lamps one lived. All brakes do is convert momentum to heat, and large rotors just soak up more heat before warping. Cooling ducts are a cheat that virtually increases the size of the brakes, like speeding up a computer chip by using a flash drive. The benefits shine under repeated hard braking, like on the track or when your Valentine One keeps going off.
    The net effect of all these evolutions: lighter weight, bigger contact patches, more and freer power, better aerodynamics, braking, shifting and grip, make the EVO2 a viscerally more engaging drive.
    The fact that your entry is welcomed by M3 sill plates, your foot is braced upon a M footrest, your torso gripped by Motorsports fabric, back branded by tricolor seat lapels, and eyes shaded from the glint of an EVO2 plaque, distinguishes the experience from a normal M3.
    EVO2 number 463 is a French car purchased in Belgium with 104,000 extensively documented and well maintained miles. I repainted the front and rear spoilers and deck, which is prone to failure. The interior is excellent and original, benefiting from a gentle, garaged patina on the grey leather that bolsters the cloth seats. The color is Macau Blue, named after the Macau Guia Touring Car Race, held on the streets of the Chinese Las Vegas since 1954. BMW won in 1987 and 1988 in M3s and adopted the name for the beloved Motorsports-only color.
    It has hints of purple when the sun is highest, fading to navy when it’s lowest. The EVO2 was available also available in Misano Red and Nogaro Silver. But the Macau Blue goes best with the silver cloth and leather interior. Red on silver? I don’t think so.
    The paint is mostly original, with a deep shine spiced by light peppering on the places where one would now put Clearbra. If you run on the Autobahn, trucks will fire debris at the rotational speed of their tires, chipping windshield and bonnet. I think of the patina as characterful, like a man in dinner jacket and eye patch, who turns to reveal a thin, cruel dueling scar; evidence of a life well lived.
    I purchased the EVO2 in Belgium and drove it for several days through the Netherlands and Germany. It was in very good, original condition. But it took six months and around $20,000 in travel, shipping, mechanical, painting and detailing to bring it to the condition it is in today.
    It comes with extensive documentation that can be viewed at the link above, French title, and complete EPA and DOT paperwork.
    EVO2s did not have a catalyst and hence you if you are in a state which requires smog you would probably have to put on a U.S. catalyst, oxygen sensor and evaporative canister in the trunk. In California only, there is the additional cost of having the car tested at a certified laboratory, which costs about $2400.
    But the costs are worth it. After all, who would want a Homo Erectus of an M3 when you could enjoy the EVOlutionary benefits of a Sapient plaything? Haven’t any of you seen the movie Quest for Fire? Buy the only M3 EVO2 that has ever been for sale in the United States and drive it off into a sunset aglow with appreciation.
    Spend $90,000 on a new Boxster and it will be worth half that in five years. Spend $90,000 on this EVO2 and in five years it may be worth double.
    The description is what all bad BMW stereotypes are made of.
    One or two lines about the racing history, many, many lines about things that don't matter. What a tool.
    So, is $90K reasonable?
    How about his assessment of an excellent standard E30 M3 at $45K
    I Timothy 2:1-2
  • markt51
    • Apr 2012
    • 329
    Too much assumption about future worth in that ad. Definitely doesn't seem like a real enthusiast. History shows a lower milage evo 2 selling for $40-50k in the past year. $60k tops.
    89 325i Coupe Auto Delphin Metallic - Sold
    91 325i Sedan Auto Brilliantrot - Sold
    83 323i Euro Coupe Manual Lapisblue - Sold
    89 325i Coupe Manual Delphin - Sold
    89 325i Sedan Auto Brilliantrot
    87 325i Vert Manual Brilliantrot
    • mkcman17
      • Jul 2010
      • 8240
      That's fine, I'll keep my neanderthal model
      1989 LN106 Hilux / 3.0TD SFA
      1974 2002tii / stock
      2002 IS300 / 5spd LSD
      • Andy.B
        • Sep 2011
        • 1650
        This makes as much sense as the sales pitch for pyramid schemes...
        "You can sell this stuff and make lots of money. See, it's so easy!"
        If you are making money from selling things locally, why would you actively recruit competition? Am I supposed to believe that the person who suckered you into this wanted you to make money that they could have made 'easily', and now you are so nice that you are doing the same? No business WANTS to pay their employees for the sake of having employees. They pay their employees for a service that they are in turn profiting from. And they certainly don't loudly tell other competitors to enter their market and challenge their market share.
        Basically, no one wants you to make money they could just as easily be making.
        (I realize this is an extremely simplified and not entirely accurate stance, but I think it at least roughly makes my point).
        "I have this car that will be worth four times what it costs now in just 5 years. Want to buy it so YOU can make that money instead of ME making that money?
        Am I supposed to believe he wants to do someone a favor and help them make money? If he truly believed the car was going to appreciate that much, that fast, then why on earth would he get rid of it?
        • jhaurimn
          • Nov 2012
          • 2224
          The guy definitely comes off as a dick in the ad. And it is overpriced, for sure.
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • markseven
            • Sep 2006
            • 5327
            I think he is factoring in shipping and EPA / DOT certification...
            +1
            Interesting perspective, that makes sense. The seller is trying really hard to make a case for a car that speaks for itself. Does a buyer for this car really need this type of education?
            Maybe he was trained at EA...
            I Timothy 2:1-2
            • Reichart12
              • Aug 2012
              • 2145
              I think I'll shit bricks the day I see an e30 M3 going for $400,000.
              Instagram: Reichart12
              • markseven
                • Sep 2006
                • 5327
                To be clear, that is what the seller claims, not me.
                I Timothy 2:1-2
                • peter321
                  • Jun 2012
                  • 221
                  lol at the 3 pics
                  • Reichart12
                    • Aug 2012
                    • 2145
                    Oh yeah I know that. I quoted your thread, guess it does look wrong that way. Sellers claim for sure.
                    • Bmwdayz
                      • Apr 2011
                      • 609
                      I've seen this car in person and I'm gonna say for 90k It should have lower mileage, No "patina" (rock chips all over the front of the car) and wheels with no CURB rash or faded emblems! haha
                      Awesome car for sure but for the price and condition it's pretty laughable. The owner bought a bunch of cars in Europe and is trying to sell them for triple what he paid. There's more to the story but I'll stop there.
                      Evo M3 really cool/ price and condition not so much
                      • DirtyDozen
                        • May 2014
                        • 22
                        Really cool car, I don't know about $90000 cool though.
                        • DirtyDozen
                          • May 2014
                          • 22
                          "Spend $90,000 on a new Boxster and it will be worth half that in five years. Spend $90,000 on this EVO2 and in five years it may be worth double.
                          At least the part about the Boxster is true.
