E30 M3 Water pump
  • medside
    • May 2014
    • 7
    E30 M3 Water pump
    I need to replace the E30 M3 water pump part#11511315211. the fan has gotten wobbly. I was wondering if any of you guys have used this pump made by GMB
    http://www.amazon.com/GMB-115-2060-R...ds=11511315211
    It runs $41 vs BMW refurbished at $260. Do you guys think its worth it to use the cheaper one, or have any of you used the GMB one before and know the quality compared to the BMW part.
    Or do you guys suggest a different solution.
    Thanks
  • reelizmpro
    • 9552
    Original BMW is best. You take a big unnecessary risk with an expensive engine using an unproven $40 aftermarket water pump.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • 1990m3
      • 1180
      stick with factory, it's not a lot of money to replace a part that should last 10+ years
      • M-technik-3
        • 18946
        Buy OEM, is it worth taking a risk cooking an S14? They are far too expensive to rebuild.
