Nice build
E30 M3 track acr build
•• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
•• Rear Subframe Bushings • RTABs • Facebook ••
donor engine:
Here are some snaps of the engine being test fitted for custom mounts to be made up:
Everything all tested fitted and ready to take out for engine bay prep:
Needed to make some modifications to allow the front ARB to go around the front as the S54 has a rearward oil pickup in the sump. ARB is hollow to keep the weight in front of the axle to a minimum.
Some ancillary bits that I've been collecting along the way:
Decided on a standard M3 wing with Carbon DTM gurney flap
Nice lite flywheel - about 4.8kg : )
Custom diff
Proper Short Shifter
Some of my own handy work - including reclocking the tach so I can see when it's getting to th business end of the revs.
