Stuck idle/throttle on S14 after warmed up
  • Chasenm3
    • 41
    Hi all, I'm experiencing an issue where after the car is warmed up and driven in any spirited manner, the idle/throttle seem to get stuck several hundred RPM higher than normal.
    Checked the tightness on the throttle cable, and all looked okay. I had a shop confirm this issue as well, and they couldn't see to find any direct cause, but acknowledged that the car was getting stuck.
    Has anyone here experienced this?
    Current:
    2002 M3 Imola
    Past:
    1992 528i Brillant Rot
    2003 330i Titanium Silver
    1997 M3 Alpine White
    2000 M5 Avus blue
    2003 M3 StahlGrau
    1991 318is BrillantRot
    1996 M3 Techno Violet
    1998 M3 Arctic Silver
    2002 M3 Topaz Blue
  • reelizmpro
    • 9558
    You need to install throttle cable clips to prevent this.
    35-40-1-165-394
    Cut the protruding piece off.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Chasenm3
      • 41
      35-40-1-165-394
      That's it?
      Current:
      2002 M3 Imola
      Past:
      2000 M5 Avus blue
      2003 M3 StahlGrau
      2002 M3 Topaz Blue
      • CurrusDei
        • Mar 2014
        • 673
        Are your throttle cables fully intact or have they developed the usual cracks behind the tightness adjustment mechanism?
        _______________________________________________
        5 Year M3 Build, In Progress
        RMT200 Retrofit
