Could have?
The offset is an inch to make the caliper be in the right position. Actually. Its an inch and 1/8.
The downfall is you lose your parking brakes. its because the flange has a huge offset. So the backing plate does not make it to the inside of the rotor.
I have made a couple versions of the adapter working on caliper spacing for the offset and the rotor spacing inside the caliper. The pad placement is pretty precise. Im sure it will work but you will toast the pad and have funny wear patterns.
Also a driveline brake would pretty pretty easy on the guibo driveshaft side :)
