I've found an intact e30 m3 parts car. Everything is there from this recently running car. Is the e30 m3 a good 5 lug swap?
e30 m3 5 lug swap Q?
^ Unless you design a new lollipop that corrects caster.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Originally posted by e30s52 View PostOr s52 but if you have money you want to spend an s62.
Originally posted by daniel View Posthere we go again
Originally posted by e30s52 View PostSorry hate old technology if that offends you in any way.
Originally posted by jrdeamicis View Post^ Unless you design a new lollipop that corrects caster.
I went the impure e36 M3 front route... my caster is within factor specs, BUT visually my front wheels are about 1/4" to far rear. Not bad huh?
"BMW Style 32 Poster-Child"
HTTP://WWW.CLAVINZERO.COM/e30-5-lug
**(My Guide to E36 M3/Z3 1.9L 5-lug Swap)**
You can just about run anything the e30 M3 can run, just stay in the et20-25 range and maybe up to 8.5" wide in the fronts (depends on offset) and 9" wide rears without any major work at all. Anything with a lower offset you will need to do some fender rolling and maybe flaring. Anything with a higher offset will require spacers to get you back to the et20-25 range.
