I was under my car looking at the lollipops while doing some other work, and i started wondering, what if i pressed the CABS out and pressed them back in not perfectly "at 9 o'clock".. because it looks like if i moved them slightly more to the 12 oclock position it would pivot the whole control arm andmake the outer balljoint point more foward . is this a dumb idea? it may not affect anything at all since just tilting the arm would still allow the outer balljoint to rotate on itself and not move the spindles position at all
re-clocking offset CABS to center wheels?
The offset M3 CABs, when in the correct position (toward the outside of the car), offer the most caster you can get with the stock "lollipops."
I have a feeling yours may be installed incorrectly if you believe you can get more caster by rotating them.Originally posted by Grueliusand i do not know what bugg brakes are.
