What's the final verdict on Z3 rear hub swaps?
    • 37833
    So much contradicting information...
    What's the final verdict on best rear Z3 setup that will retain stock E30 trailing arms and stock E30 axles?
    What hubs?
    What brakes?
    Thanks. :)
    Grover Beach, California
    BimmerHeads.com
  • Aptyp
    • 6584
    z3 hubs from I-6 models with all z3 brakes.... there shouldn't be anymore contradicting information since http://www.torque-bound.com/5-lug.html
    when it comes to z3 hubs there's nothing new to be learned between Clavin and I.
    • JoshWho_e21
      • 109
      Praise MR 325!
      • Shaun K
        • Apr 2004
        • 174
        I-6 Z3 only? I thought you could use 1.9 Z3 stuff too?
        1989 325is w/M52 swap
        1989 320i coupe, mostly stock
        • clavinZERO
          Hella sick E30
          • Mar 2004
          • 2027
          Use just the z3 6 cylinder hubs/bearings and the brake parts.
          or
          Use complete z3 1.9L / 318ti (4 cylinder) trailing arm assemblies with everything on them (brakes, hubs, etc.).
          If I am not mistaken, the 4 cylinder z3 / 318ti has a deeper hub with narrower arms, and the 6 cylinder z3 has shallower hub and wider arms... all yielding the same offset in the end.
          Going the z3 1.9L / 318ti way gives you SLIGHTLY smaller rear wheel bearings... enough for Aptyp to hate
          "BMW Style 32 Poster-Child"
          HTTP://WWW.CLAVINZERO.COM/e30-5-lug
          **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
          • Mr.SWISS
            • Nov 2005
            • 1251
            And use e30 M3 for the fronts? Is there ANY other way? I have a set of GC Z3m fronts. I wonder if I can use those with a 1.9 hub and just dial it in...
            Any been there tried that epic failz?
            Originally posted by 325Projectz
            don't listen to the diagram... listen to mr. swiss.
            :nice:
