Just completed swap!! but front wheel not centered, what´s wrong ?? Please help!
  • 2002maniac
    • 4260
    #31
    Originally posted by Aptyp
    Moving strut mount forward make surprisingly a big difference. Moving up top by 10mm still move wheel hub about 6mm forward. Doesn't sound like a lot, but it really does look much better. This is because you're pivoting entire strut assembly over the outer ball joint. I also imagine that it would help reduce bump steer, because tie-rod also moves lower (but only by 1-2mm).
    The only problem is that this will screw up your caster even more. The wheel will be more centered, but caster will suck.
    • Aptyp
      • 6584
      #32
      that's the way BMW engineers took care of the issue on all e36s. They moved strut tower forward on otherwise identical design to e30. So I feel like caster is perfectly fine, but I understand what you mean.
      • Fair!
        • Mar 2007
        • 202
        #33
        Yea, we will try to adjust out some of the massive positive caster at the top.
        Terry Fair - www.vorshlag.com
        Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
        • SA E30
          • 1248
          #34
          Just out of interest those front damper's looks like the exact same housing as my BMW E36 328i Group N BMW Motorsport/Sachs Dampers.
          Do you have the part no. from them by any chance?
          • Aptyp
            • 6584
            #35
            i think South Africa saw a lot of different variants of BMWs. Post up pics of what you got.
            • SA E30
              • 1248
              #36
              I took them off a E36 328i Group N car. It was running 900lbs front springs.
              I have checked the valving on them and they are spot on for a 800-1100lbs spring range.
              Don't mind the roll centre spacer it was just a mock up version... Actually don't mind anything as most of it has been changed since then.
              • b1gturbo
                • Jul 2012
                • 4
                #37
                anyone figure out the lolipop bushings? or just moving it 10mm up top will do it all? while running e30 m3 lower bushing ( lolipop ) im running e36 bilsteins coil overs e36 m3 controll arm from a 96- up... and e36 hubs. with a e36 rackk.
                i cut the towers out.. and moved them 1cm forward seemd to fix the problem..
                e30 m62 enough said.
                • goarmy
                  • Nov 2011
                  • 622
                  #38
                  There are these options
                  UUC:
                  OR
                  EBay:
                  http://www.ebay.com/itm/BMW-E30-Z3-3...RV1bb-&vxp=mtr
