Just completed swap!! but front wheel not centered, what´s wrong ?? Please help!
Terry Fair - www.vorshlag.com
Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(Comment
I took them off a E36 328i Group N car. It was running 900lbs front springs.
I have checked the valving on them and they are spot on for a 800-1100lbs spring range.
Don't mind the roll centre spacer it was just a mock up version... Actually don't mind anything as most of it has been changed since then.
anyone figure out the lolipop bushings? or just moving it 10mm up top will do it all? while running e30 m3 lower bushing ( lolipop ) im running e36 bilsteins coil overs e36 m3 controll arm from a 96- up... and e36 hubs. with a e36 rackk.
i cut the towers out.. and moved them 1cm forward seemd to fix the problem..Last edited by b1gturbo; 07-29-2012, 09:22 AM.e30 m62 enough said.Comment
There are these optionsanyone figure out the lolipop bushings? or just moving it 10mm up top will do it all? while running e30 m3 lower bushing ( lolipop ) im running e36 bilsteins coil overs e36 m3 controll arm from a 96- up... and e36 hubs. with a e36 rackk.
UUC:
OR
EBay:
