E30 M3 5 lug swap...what can i get away with?
  • Addissimo
    • Mar 2004
    • 1820
    I got a quote of $80 each from Patrick at bma
    -Addis
    edit: My bad - that was for an m roadster.
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • nefarious7907
      • Jan 2005
      • 1170
      what can i get away with.....
      Reusing springs can i reuse my bilsteins and H&R sports in the swap.
      http://www.cardomain.com/ride/657387
      • Addissimo
        • Mar 2004
        • 1820
        If you have the later style strut tubings, then yes.
        -Addis
        • static
          • Oct 2005
          • 501
          ok, i am a bit confused
          i have a '91 325i. Can i get away with just hubs and brake components? i.e stay with my old strut housings?
          or would that not be a good idea/not work at all?
          Thanks
          Alex
          • Jordan
            • 12916
            You cannot put a e30 m3 hub/wheel bearing on the non-m spindle. Will not fit.
            You need the complete front M3 strut housing/hub/rotor/caliper/etc
            https://mtechniqueabs.com/
            • gstuning
              • 833
              What is the direct diffrence in the M3 struts and non M3??
              pics if possible please.
              Gunni
              @ Prodrive / Aston Martin Racing
              • Jordan
                • 12916
                Many differences Gunni.
                M3 wheel bearing/hub much larger.
                5x120 vs 4x100 obviously.
                M3 spindle is much larger
                Same strut inserts as 51mm non-m housing
                Same spring perch (thus could use all spring)
                M3 housing has a detachable lever arm at the bottom (tierod and CA mount to this) non-m is part of the whole housing.
                Geometry of said lever arm is different then non-m
                I don't have any GOOD pictures comparing the 2 handy, but I can get some.
                • gstuning
                  • 833
                  I was mainly thinking about the possibility of machined parts to fit M3 hub on non m3 spindles(I´m assuming that is the part the hub goes on to).
                  but without M3 geometry
                  Gunni
                  • Jordan
                    • 12916
                    Is is possible? Certainly.
                    Should you ever do it? No.
                    • 1991 318is
                      • Dec 2005
                      • 786
                      About the bars.
                      The M sway bar is smaller but the geometry makes it's effective rate stiffer and less likely to bind. The E30 pickup point is on the control arm and moves proportionately less than the road wheel. The M3 pickup on the strut is a 1:1 ratio with the road wheel. It's like a spring that is weaker but is compressed more. Same principle as adjustable bars.
                      This was noted recently by another poster - all I remember about him is the Buddy Holly glasses and maniacal gleam in his eye. See #2 below.
                      Main Entry: ma·ni·a·cal
                      Pronunciation: m&-'nI-&-k&l
                      Function: adjective
                      1 : affected with or suggestive of madness
                      2 : characterized by ungovernable excitement or frenzy :
                      • rede30
                        • 4697
                        I didnt know you just need to press in a new bearing and an m3 hub for the rear. Why dont people do this? whats the bad. Can you not fit fatty tires? can you not fit e36 m3 brakes? there has to be somthing.
                        • BahnE30
                          • 1050
                          because you need a press to put the M3 bearings in, if you have used parts 9 times out of 10 the hub comes with a trailing arm and it's just a simple swap then.....
                          • Borat
                            • Jan 2005
                            • 494
                            are the brake mounts different between E30 trailing arms and MZ3 arms? Basically can E36 M3 brakes be put on E30 arms?
                            • Jordan
                              • 12916
                              Yes.
                              No.
