I want five lugs, bigger brakes, and I don't want to pay an arm and a leg for an E30 M3 suspension. I want to do the E36/318ti brake and suspension swap, but I have limited information. Here's some info I got from someone who has done this swap:
Can anyone provide more details?
Basicaly we took the front strut and hub assembly off a E36 and bolted it on. You need a couple of things. Don't throw out the strut ower mounts as the bolt pattern isn't the same between the two platforms. You will also need the M3 offset control arm bushing as the caster will be way off. We had to do some fender well "modification" to make the 17" wheels and tires fit. I don't know about ride hight using stock springs as we are using GC coil-overs. That may be off as well.
The rear is simpler, but harder to install. Just get the whole trailing arm/hub assembly off a 318ti or Z3/MZ3/M coupe. Pretty straight forward. The 318 rotors are solid and the Z3/MZ3/M coupe are vented, FYI.
No changes need to be made to the booster or master cylinder. We even have a smaller 320 booster as we have the M50 conversion, and there are no problems with pedel travel or feel.
