help with e30 m3 five lug
  • for3ver
    • Apr 2007
    • 329
    Hey I found a guy who is selling his suspension off a 89 m3. What do I need to take off it? I know I need the front struts and hubs, and rear trailing arms and hubs, and tie rods. What else do I need? Do I need the control arms?
  • Gooch
    • Dec 2006
    • 1674
    For e30 M3 five lug you need:
    Front hubs, strut tubes, sway bar links, and tie rod levers
    Rear hubs (trailing arms are the same)
    You do not need tie rods, they are the same.
    EDIT: Any other questions, feel free to ask.
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      If it has the aluminum control arms, take them. Get all the brake equipment as well, including e-brake cables. Yes on sway bars and endlinks too.
      • Gooch
        • Dec 2006
        • 1674
        Yeah, my bad, Farbin is right. You need front and rear calipers and carriers. I reused my brake cables and e-brake assemblies.
        '09 328xi - 6-speed
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          ^ Yeah, a lot can be reused, but, it's easier to go up to the car, pull the rear arms, then disconnect cables, that way you don't have to open anything up, and run the risk of losing a bolt or part.
          With the front, pull the strut mount top bolts, the brake hose, the control arm bushing bolts, and the one ball joint, then take everything as a whole up there too.
          • sonnyqm3
            • Sep 2009
            • 1144
            if you dont buy it then let me know.. I need e30 m3 suspension parts and if he has interior for the e30 m3 then let me know as well..
            • for3ver
              • Apr 2007
              • 329
              Well I got the parts! But he cut the e-brake cables in the process. Are the cables the same on the m3 and a 3 series?
              • FredK
                • 14752
                Yes, the cables are identical.
                • for3ver
                  • Apr 2007
                  • 329
                  What about the rear wheel bearing?
                  • Van Westervelt
                    • 9365
                    The rear wheel bearing is the same, but the hub flange is the different part on the rear.
