Why?
  • VinniE30
    • 2113
    Why?
    Is there any advantages of converting to 5 lug besides obviously more wheel options? If not then it doesn't really seem worth it at all. There's tons of 4 lug wheels, all the ones that look the best on the e30.
    Zinno '89 <24v swap in progress>
  • Teaguer
    • Sep 2004
    • 6167
    Well the most obvious advantage would be bigger brakes.
    The most stupid reason is for wheel options.
    • Aptyp
      • 6584
      because it's fun...
      • nu-B
        • 85
        ie sells big breaks so I say ta hell with the 5 swap.. un less you really like other bmw wheels. aftermarket is aftermarket doesn't matter 4 or 5 they still turn peoples heads the same. now oem bmw wheels just rile up other bmw nuts. most people don't give two licks.
        • deutschman
          • May 2008
          • 5958
          because people run out of things to do to their e30's!
          • etxxz
            • Feb 2006
            • 2085
            as a 5 lug e30 i will agree with you.
            I swapped becuase i had a cheap opportunity for big brakes and i regret it.
            Yes the brakes are awesome and my e30 looks sick as hell, but i would have rather gone with a BBK for my 4-lug and stayed max 15" wheels.
            They are smaller lighter rubber is cheaper and i can turn full lock.
            The 5-lug threw my geometry i had to use ridiculous 225/35-17 on the front and i still rubbed while drifting. I eventually had to bang at the frame with a sledge hammer and after all that aggravation 17" r-comps are really expensive... oh, with the e36m3 fronts, you can't fit anything smaller than 17" or it won't clear the brakes.... it does look ridiculously sexy, that is fo sho
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
            • Van Westervelt
              • 9365
              I got 2 setups for a steal, and wanted the bigger brakes on my s50 car. Due to the sale (s50 car), I swapped the 5 lug over to my 4 door eta mtech project. I would much rather have a brake upgrade and some old school 4 lug 16s.
              I already had a plethora of 5x120 wheels too, so here I sit, unwillingly 5-lugged. lol
              • hoveringuy
                • Dec 2005
                • 2728
                I swapped because I loved the look of the DS2's and wanted better brakes.
                I got the brakes, but became disenchanted with the character and "manners" of the car. It took expansion joints horribly.
                I had a can of "fix a flat" instead of a spare.
                I swapped back to 4 lugs and will never go back; it drives and handles so much better now and has that je ne sais quoi that I was missing.
                Edit: Just because I can use je ne sais quoi in a sentence doesn't mean I'm a fag.
                • HybridNz
                  • Jul 2009
                  • 158
                  Try running 18's :) I have got it so it doesnt rub. You just need Tree House racing offset eye ball arms to push the control arm forward an inch to center the wheel properly.
                  As for geometry, just get it professionally setup and run some front camber with toe out for turn in = solved.
                  • etxxz
                    • Feb 2006
                    • 2085
                    I think the lollipops are the only thing i'm missing. I actually banged up the back of the wheel wheel for clearance, but the frame is too damn hard, even for a sledge hammer. I ended up getting 15mm spacers for the DS1s and DS2's that i own. That worked really well. I'm maxing out my camber and caster on my plates too -.-
                    people don't realize that they need a brake bias on the front brakes. The difference in piston is drastic + the rear has a stock limiter valve. I bet you skidded the front everywhere. After the bias, my car brakes like a monster!
                    91 BMW 325i [sold]
                    • bmw325csi
                      • May 2007
                      • 4045
                      with the options of 4 lug wheels, BBK and re-drills available for the e30 nowadays, i say leave it alone, that is unless you can afford a real e30 5 lug swap from the e30 m3.
                      harry/harout
                      • Boosted E30
                        • Dec 2009
                        • 288
                        What did you do to balance the brakes better? Im running the e36m3 up front and under heavy braking the back end gets a little light.
                        • etxxz
                          • Feb 2006
                          • 2085
                          well i used this particular valve:
                          http://store.nexternal.com/ireland/b...alve-p247.aspx
                          now, describe the rear gets light? Might have to do with your suspension. In my case, the front locked up ages before the rear so i had to put this valve on the front brakes and tune them down. Took about a whole morning at the track to set them up.
                          91 BMW 325i [sold]
                          • Boosted E30
                            • Dec 2009
                            • 288
                            My fronts will lock way before the rears aswell, i dont know if the rear gets lite is the right way to describe it because it not like the rear end wants to come out under braking but its definatly lacking rear braking power.
                            So you installed that valve into the front line and tuned down the fronts to even it out with the rears? Did you upgrade the rear pads aswell?
