The 5 lug swap truth thread!!!!!!!!!!
  • etxxz
    • Feb 2006
    • 2085
    Originally posted by mikeedler
    dug out the very first allignment specs sheet.
    I forgot to add in my orig. post-- I also have an assload of washers on the lower bolts of the strut tube to give the car a better amount of camber.
    here is what I have........
    L/F camber -0°48´ R/F -0°54´
    toe 0°06´ 0°06´
    L/R camber -1°54´ R/R -2°18´
    toe (crapy but cant do anything 0°12´ -0°18´
    and the F**King caster isnt on the crappy sheet, I will stick it on there next week again and get that.
    hmmm i had the same problem on the front. With the washers and EVEN with maxed out camber plates i'd have little camber up front.
    lower your LR, give you a bit more camber and match it up if you have coilovers.
    your car should drive straight as a bullet. I'd look at slop in your steering components - bushings tie rods balljoints. You have a better alignment that me. OR if your tires are worn unevenly that'll do it too!
    @psyber_Optix: that's why i added a brake bias on the front brake line, otherwise the brake bias to the front is ridiculous. I tuned it originally to lock up all four at nearly the same point/threshhold, but that proved to be dangerous at the track so i opened up the front a bit. The point was to use the rear brakes for something. Brake Bias valve is a MUST on e36 stuff. Otherwise, that person is a poser and i will hate all i want. I have the right to be a hater..
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • mikeedler
      • 6707
      LR? I have a rear subframe at the sandblaster that will be recieving the adj. crap whenever it gets back to get the rear to reasonable specs.
      Everything EVERYTHING on my front end is BRANDNEW original BMW components including the brakes front and rear. I am running coilovers too, but am already VERY low.
      • Javier h
        • Sep 2007
        • 1189
        So the M3 e30 setup would be the way to go for a 5 lug swap, right?
        Are there any issues?
        • DTM190
          • Nov 2008
          • 1107
          Finding the parts at a reasonable price is the main hurdle.
          Originally posted by der affe
          first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
          if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
          • etxxz
            • Feb 2006
            • 2085
            your rear specs look good. the e30 trailing arms have this geometry such that the camber changes A LOT as it compresses. so if you lower your e30 is the same as compression you get camber. lower one, or raise the other. that's what coilovers are for ; /
            91 BMW 325i [sold]
            • Jason89i
              • Sep 2004
              • 875
              d......
              before you go start saying "5 lug sucks" blah blah blah.... fix your rear toe. anything close to positive rear toe will make the car EXTREMELY darty at high speeds.
              as a bmw tech, you should know this.
              I have been driving my 5 lug swap car for a few weeks now .....
              front-- e36 coilovers (raceland)
              non M brakes
              97 &up control arms
              E30 M3 lollipops
              E36 steeringrack
              wheels are 17x8 style 5 BBS e34 fittment ET 20 somrthin.
              It looks like you used the e36-325i king pins........and i bet your caster is +/- 9.8 . Might consider using the right kingpins.
              cheers, jason
              • mikeedler
                • 6707
                cheers, jason
                as a tech, I stated I am not happy with the specs of the rear toe, but it is still within BMW's specs.
                and what are the correct knuckles to use? as from what I have searched, except for M from a 318 to a 328, they are all the same. AND I am 100% sure the kingpin will NOT change the incorrect caster it is just larger bearings.
                So once again, its a crappy setup that is not correct and still handles like crap. the car drove for over 20 years with that rear axle and it wasn't darty.
                • psyber_0ptix
                  • 904
                  the 96+ e36 m3 kingpins/knuckles are indeed different and are needed to do this properly. Give it a shot before you claim it won't work. what can you base your 100% assurance on?
                  Originally posted by FredK
                  However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                  My year in Germany
                  Feedback
                  • Van Westervelt
                    • 9365
                    So glad I dont have to deal with any of this. E30 m3 bits, ftw.
                    • Stephen
                      Шлем ишака
                      • 10774
                      seems like alot of work and hassle to have a shitty wheel selection
                      • Jason89i
                        • Sep 2004
                        • 875
                        as a tech,
                        no credentials needed. it is ok to come here and post opinions. just dont spread mis-information under the title "im a bmw tech."
                        your still wrong. there is indeed geometry differences between the e36 and e36m kingpins.
                        cheers, jason
                        • psyber_0ptix
                          • 904
                          This is definitely the most performance effective route, its lighter and offers perfect braking balance. It just sucks that these are golden parts.
                          My year in Germany
                          Feedback
                          • mikeedler
                            • 6707
                            cheers, jason
                            I posted that as a joke because you posted earlier that as a tech.... I should know, anyway.. enough of that.
                            Better yet, please prove to me that there is a difference in the caster with the M3 kingpin. If the CASTER was different due to that piece, there would be no difference in the control arms or lollipops , please show me how you have this info.
                            • mikeedler
                              • 6707
                              right, I am going to spend another 500 at least on a set-up that I already know fits like crap.
                              I am 100% sure of this because AFTER BEATING my firewall(innerwheelwells) 8" inward with a sledgehammer to fit 205/40/17 tires-- no kingpin in the world is going to sit my wheels the needed min. of 3 " further forward.
                              you guys are WRONG to try to argue that this is a good set-up and this is what I am trying to get across, it sux and should be said. I got sucked int dropping a min. of 1500 dollars into crap that you guys are telling everyone is good. it doesnt fit and doesnt even drive good.
                              maybe, just maybe the M3 kingpins will make a bit of difference, but a real tire size on a lowered car it still is crappy geometry and will still rub like crazy.
                              • psyber_0ptix
                                • 904
                                i"m sorry you didn't know the correct parts to get the first time around. I didn't have to hammer anything out and my wheel sits perfectly where it should. I only invested about $800 into my entire 5 lug and e36m3 front conversion.
                                i dug up a link you might want to read through
                                ***I originally used standard e36 spindles and brakes, but caster just does not work out. Wheel sits too far back and very often rubs. However, you may use standard e36 spindles and brakes, I did for a good number of months, but you HAVE to figure out caster. I used camber plates to fix caster just enough to reduce rub. Personally, if you're going through this conversion, do it right the first time
                                Servus
                                Last edited by psyber_0ptix; 06-08-2011, 01:37 PM. Reason: because i was a jerk, but didn't mean to be
                                My year in Germany
                                Feedback
